Coolant filter necessary?
Old Dec 2, 2022 | 05:19 PM
Hyakkimaru's Avatar
Hyakkimaru
I'm thinking I should at least temporarily put one on to check for depris. Which one should I get? I still haven't seen any pictures of how you'll have them set up. Is it too much of a pain to install one?
Old Dec 2, 2022 | 05:24 PM
pvdiag's Avatar
pvdiag
Originally Posted by Tpayne621
If I rememebr correctly you were flushing without removing the block drain correct?
You are correct and I agree. However, the degree of stuff I had in there was way over the top and is now to a level that seems more manageable. Once winter is over, I can revisit the drain/flush with the plugs out when I don't have to worry about negative temperatures. I will try to slam in the cooler soon though.
Old Dec 2, 2022 | 05:38 PM
F0rdc0wb0y's Avatar
F0rdc0wb0y
Here’s a riffraff setup. I don’t use the hoses they supply. I use a hose barb and some coolant rated 3/8 hose.
Old Dec 2, 2022 | 06:09 PM
Hyakkimaru's Avatar
Hyakkimaru
Oh, just hooks into the overflow? Where does the downward directional hose go?
Old Dec 2, 2022 | 06:12 PM
Tpayne621's Avatar
Tpayne621
There is a npt plug in the driver side of the water pump right under the thermostat.
Old Dec 3, 2022 | 05:27 AM
FordTruckNoob's Avatar
FordTruckNoob
@Hyakkimaru Sorry it’s taking me so long to get a picture. Mine is similar to what is shown above except mine is homebrew.
Incidentally, the International water pump has the filter integrated into it if you are looking for a more compact solution.
https://www.dieselsite.com/OBSford73...antfilter.aspx
Old Dec 3, 2022 | 09:35 AM
Hyakkimaru's Avatar
Hyakkimaru
Ohhh I like that. Maybe I should wait till I have to do a water pump and do that 😂
You liked the wrong year model but I found the one for my 2000 shortly after clicking your link. Thanks!
EcoboostKev
Aug 18, 2015 02:07 AM
DavidE
Jul 16, 2014 01:03 AM
Poorboy04
Feb 27, 2013 02:42 AM
speedtrapp
Oct 10, 2012 08:24 AM
