E450 Motorhome Misfire
No on both, where do we find specs on what those values should be. I do have a scanner that I think I might be able to check MAF sensor. What about the EGR could it be stuck open and not throw any kind of code?
MAF sensor should read 6-8 g/s at hot idle, 20-25 g/s at 2500 RPM. You may have to do units conversion depending on how your tool displays live data. Google has tools to do this.
FP should be between 30-45 psi. You want to make sure it isn't dropping off at the time the misfires are observed as fuel starvation can cause misfires as well as "lean" codes when fuel demand is high.
OK I borrowed a better scan tool here is the freeze Frame. This tool is only showing 1 DTC Cylinder #6 Misfire. Cylinder #6 was the one that blew the plug out.
Short Term Fuel Trim Bank 1 2.3%
Long Term Fuel Trim Bank 1 9.4%
Short Term Fuel Trim Bank 2 7.0%
Long Term Fuel Trim Bank 2 0.0%
RPM 3289
Speed 57mph
RPM 3289
Speed 57mph
I'm not sure it was done by a Ford Dealership. I'm assuming since it was a dealer a brand name insert was used.
The problem was the hack job helicoil the dealer used. The cylinder would not build compression. We tried the expensive insert that used JB weld but the cylinder was still dead, Ultimately paid $9000 for a complete engine overhaul with brand new aftermarket cylinder heads. Motorhome runs fantastic now., The cheap repair hack job the dealer did caused low compression and carbon build up on the compression ring and it no longer sealed. The heads I got have 10 threads per sparkplug Guaranteed to never blow out a sparkplug.
Oh, boy. OK thank you. Glad you are back up and running. Just picked up a 2000 E450 Motorhome with 75K miles. On my test drive it ran fine. On the 100 mile drive home on some hills, it misses slightly depending on how much I put my foot into it and I also lose dash air on the face, comes back after cresting a grade, that one I can fix. Occasionally it runs rough at idle but not all the time. Original owner Records (I am 3rd) indicate plugs checked for torque at 30k and were OK and were replaced about 3k miles ago. No indication of inserts on receipts. One coil was replaced at some point as well for a miss. I need to look for any pending or stored codes. It sat for 2 years before 2nd owner bought it, it was not used much in the year the 2nd owner had it. Seafoam comes to mind as well.
good luck with this problematic v-10 pos. Replace all your COPs with a new set of Motorcraft. The blower is unrelated to drivability but equally annoying. Google something about F450 blower switches while driving. There is a vid on utube showing how to install a new vacuum canister and bypas FORDs ****** placement of the factory canister and check valve. I hate FORD products and this motorhome strengthens that hate. Im looking for a Super C or Chevy Chasse.
nerider
Modular V10 (6.8l)
04-28-2009 09:06 AM
