FX4 4x4 payload difference?
Old Nov 30, 2022 | 08:40 AM
Flashracer's Avatar
Flashracer
Is there a difference in the payload? Which has the highest payload? Thanks
Old Nov 30, 2022 | 08:46 AM
#1bigmark's Avatar
#1bigmark
Temporarily Deactivated
Read the thread above about towing guide being released and click the link. All the numbers are there for you including payload.
Old Nov 30, 2022 | 08:59 AM
Johnny F2 fiddy's Avatar
Johnny F2 fiddy
Quick answer.....if the FX4 package adds weight above a non FX4 truck, then yes, the payload goes down.
PAYLOAD = GVWR - Actual truck weight.
Old Nov 30, 2022 | 09:01 AM
acdii's Avatar
acdii
You will lose some payload due to the skid plates that are part of the FX4 package. Ford has really downgraded the FX4, now it is just skid plates, downhill braking, and a sticker, even the shocks have been removed and are standard shocks(probably because of all the complaints on how they suck).
Old Nov 30, 2022 | 09:02 AM
scraprat's Avatar
scraprat
Top Answer: 5
It all comes down the amount of crap and luxuries you add to the truck and then get a weight on the truck. More you add less you can carry or tow no matter what the generic brochure number claims.
Old Dec 1, 2022 | 12:46 PM
speakerfritz's Avatar
speakerfritz
I read in another thread that all FX4's are limited slip whereas non fx4's may or may not be limited slip.
Old Dec 1, 2022 | 12:55 PM
CheeseheadFord's Avatar
CheeseheadFord
My derated F250 FX4 is right around 3k payload (give or take 25 lbs one way or the other, I forget), the FX4 package in itself takes little away from payload but it does and everything added adds up as someone else pointed out.
Old Dec 1, 2022 | 01:02 PM
acdii's Avatar
acdii
Included with FX4, They do still use different shocks, Shocking cause they are schiznit
Hill Descent Control™
Transfer case and fuel tank skid plates
Premium Off-Road Shocks
Unique "FX4 Off-Road" box decal
NOTE: Specially tuned shocks intended for significant off-road
usage will result in a firmer ride than may be desired
when the vehicle is used for primarily highway driving
The FX4 USED to include a locking axle, but hasn't for a few years now.
Old Dec 1, 2022 | 01:38 PM
Johnny F2 fiddy
On the FX4, it was Electronic Locking differential, so the driver could pull out on the 4x4 selector ****, and lock the rear axle. I had many situations where doing that was enough, and I didn't need to go in to 4wd.
Dually's have Limited Slip Differentials, but they are NOT Electronic Locking selectable by the driver.
Old Dec 1, 2022 | 01:48 PM
4wd6.7L's Avatar
4wd6.7L
All SRW FX4's have the locking rear diff, none have limited slip. That is because the locking rear diff is a forced (required) option to allow the FX4 package option. Not sure about DRW, maybe the FX4 package forces the LSD rear since locking rear is not available on DRW. Obviously a non FX4 Super Duty can have whatever diff option is chosen and available for that particular configuration.
Old Dec 1, 2022 | 01:50 PM
4wd6.7L's Avatar
4wd6.7L
Originally Posted by Johnny F2 fiddy
Dually's have Locking Differentials, but they are NOT Electronic Locking selectable by the driver.
DRW do not have any sort of locking differential option, the only diffs under a DRW are open or limited slip.
Old Dec 1, 2022 | 01:58 PM
Johnny F2 fiddy
Yes, I meant Limited Slip.
Old Dec 1, 2022 | 04:03 PM
acdii's Avatar
acdii
The M300 axle on DRW are all LS axles. The M275 on SRW can be open or E-Lock.
Old Dec 1, 2022 | 04:40 PM
chadstickpoindexter's Avatar
chadstickpoindexter
This is the first year that the FX4 package actually has a reason to add it, although, it is still way overpriced, in fact, even more so than the previous years. Prior to the 23's you could add the skid plates ala carte for $100, now though it appears you can't, so you're stuck with the $500 FX4 package! The only reason to get the FX4 package now is if you want skid plates. But as has been mentioned, all the FX4 package gets you is the skid plates, a sticker, the hill descent button and "off road tuned shocks" which aren't anything special. You're better off getting a set of Bilstein or Fox shocks after market. All that other stuff that people think comes with the FX4 package doesn't... 4X4, electronic locker, AT tires, etc... those are all things that you must add to your build before it will allow you to add the FX4 package, and none of them are any less expensive, or function any better/differently because of the FX4 package.
And if you are adding it for "resale value" then just pick up the $10 FX4 sticker from eBay before you sell it... the folks wanting it won't actually know what it is... lol.
Old Dec 1, 2022 | 04:41 PM
speakerfritz
very helpful
