Doing it myself
Old Nov 13, 2003 | 08:35 AM
Fordafied's Avatar
Fordafied
Thumbs up Doing it myself
Thanks to all of you with your great info and knowledge, I have changed oil, fuel filter and trans fluid myself. Like most of you, I don't trust my truck with NO one else. I used Rotella T, Fram filters and synthetic trand fluid. I do have one question though. I noticed some trash/debris in the bottom of the fuel "bowl". I tried to get out what I could but there was a little left. Is this something that is common?
2000 4x4 PSD, CC, REAL TRUCK!
Old Nov 13, 2003 | 09:15 AM
alanscott's Avatar
alanscott
Do a bit more searching in the Oil and Lubrication forum and you'll probably give up on using the Fram filters.
The crud in the bottom could be corrosion from water that's wasn't drained for a long period.
Old Nov 13, 2003 | 09:16 AM
oppy's Avatar
oppy
I don't think it's a huge issue unless there's a lot of it in there. You may want to change where you fuel up and see if it looks cleaner.
Old Nov 13, 2003 | 09:18 AM
oppy's Avatar
oppy
Let's not start another bash Fram thread - I just got done with the last one
Old Nov 13, 2003 | 10:27 AM
Fordafied's Avatar
Fordafied
Oh my goodness, must to have been a brain fart. I used Motorcraft filters. I had to go to the dealer to get the fuel filter though. Cost $48.50. Local Advance Auto had the oil and oil filter. I found it funny none of the locals (Napa, Auto Zone or Advance) had the fuel filter (Motorcraft). Must be a conspiricy. Fram where the heck did that come from.
Old Nov 13, 2003 | 10:44 AM
oppy's Avatar
oppy
Originally posted by Fordafied
Cost $48.50
Oh my god! I think you can mail order them from DIS for around $15. The most I ever paid was $23.
Old Nov 13, 2003 | 02:45 PM
Stinger_916's Avatar
Stinger_916
I just bought a fuel filter from NAPA for around $20.00. Just a reminder if you get a filter that comes with a new cover do not throw away your old cover. My last filter came with a new cover and I cleaned up the old one and put it in the tool box good thing I did because I just replaced it and the new one did not come with the cover. So if you have the room keep all stock parts if you want to .
Old Nov 14, 2003 | 05:20 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Trash in the bottom is fairly common. I'd remove the pipe (nut at the bottom is backwards thread), remove the heater element then clean it out real good. These housings are know to corrode through and if that junk stays in there that might happen to you. I've read they cost many hundreds of $$$ for a new bowl.
And do you remember to drain the water out periodically? That might help wash some of the stuff out of there, too.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Nov 14, 2003 | 07:26 AM
99f250's Avatar
99f250
is there a difference if you drain the fuel bowl out when its running or not?
Old Nov 15, 2003 | 08:30 AM
Phat02's Avatar
Phat02
My local Advance has the fuel filters also.
Old Nov 15, 2003 | 12:02 PM
MrFeexit's Avatar
MrFeexit
DOH!!!!! I threw mine away when I changed the filter....never thought of the next filter maybe not having one...
Old Nov 15, 2003 | 12:18 PM
alanscott's Avatar
alanscott
I drain mine with the engine off just so the water is at the bottom and not being stirred up by vibrations.
Old Nov 15, 2003 | 02:05 PM
so2315's Avatar
so2315
How often do you guys drain? Just a newbie asking a dumb question.
Old Nov 15, 2003 | 02:39 PM
MrFeexit's Avatar
MrFeexit
When ever I change oil..don't know if thats the right schedule or not but then is when I do it
