Won't Start
Old Nov 28, 2022 | 06:00 PM
hcantrell1977's Avatar
hcantrell1977
5th Gear
Won't Start
Hey all, sorry if this has been asked. I searched for my problem but didn't find anything. I have a 2017 F250 Lariat. After it has sat for 2 plus days, it won't start. I thought at first that I had a bad battery. Got the batteries tested and they're good. I can jump start it and it will start up. Once it reaches operating temp, it will start just fine. But if I let it set again, then I have to jump it to start it again. I've done some research and found that the fuse box is notorious for being faulty, but not sure what I would check to determine if that's the issue. Has anyone else had this issue, or possibly know what I could do to figure this out? Thanks for any help you can provide.
Old Nov 28, 2022 | 06:16 PM
chadstickpoindexter's Avatar
chadstickpoindexter
If the batteries are still the originals I would start with replacing them.
Old Nov 28, 2022 | 06:24 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
When asking for mechanical advice, the details of the truck are needed, as well as the details of the symptoms.
Diesel or gas?
And, when you say it won't start after sitting a couple of days, does the engine turn over at all, or does it just click and then do nothing?
And, you say the batteries were tested, but how were they tested?
Old Nov 28, 2022 | 06:41 PM
senix's Avatar
senix
If the batteries were tested in the truck and connected (not islolated from each other and the truck) then that is most likely your issue.
You are not reporting a check engine light or the battery light illuminated so battery time.
Replace both if we are taking diesel
Old Nov 28, 2022 | 07:27 PM
hcantrell1977
5th Gear
Sorry, yes it is a diesel. The batteries were in the truck when they were tested. Thanks for the advice.
Old Nov 28, 2022 | 07:29 PM
hcantrell1977
5th Gear
Diesel or gas?
Sorry, should have included that it was a diesel. It turns over but won't start. The batteries were tested in the truck. Thanks for the reply.
Old Nov 28, 2022 | 07:44 PM
1olddogtwo's Avatar
1olddogtwo
1st, how old are the good batteries?
2nd, when turning over, is it at a normal pace or slower? I'm assuming slower. I believe the engine needs to turn over in the min of RPM to fire off the injectors.
Need to test the batteries independently. One bad battery will drag down the other.
Old Nov 28, 2022 | 08:19 PM
morehouse7's Avatar
morehouse7
Always replace them in pairs as Senix said, and get a good set of AGMs like Northstar or Odyssey.
Old Nov 28, 2022 | 08:33 PM
hcantrell1977
5th Gear
To my knowledge, they have not been replaced. I bought the truck used a couple of years ago. I would say the turnover is a slower pace. I will test independently and I appreciate the feedback.
Old Nov 28, 2022 | 08:39 PM
hcantrell1977
5th Gear
Will definitely replace both. Thanks!
Old Nov 28, 2022 | 09:10 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
If the starter turns the engine over but it doesn't start, then that is not batteries.
Sounds more like a fuel system issue.
