'97 CPS issues, still?
Old Nov 28, 2022 | 05:19 PM
Randy Bright's Avatar
Randy Bright
7th Gear
So, right after I bought my 97 F250, I replaced the cps. However, silly me, I lost the original bolt that secured it in place. I scrounged and found another bolt that seemed to work. Right thread, etc. Since, I've had the truck to a couple different mechanics, and both replaced the cps (Ford Motorcraft OEM), reusing my scrounged bolt.
I'm still having issues with a crank no start. I followed the flow chart in stickies and it points me directly to the CPS ("wait to start" lights, but the tach doesn't register while cranking). So, I'm wondering, could the bolt be the issue? If so, how can I go about getting a replacement?
​​​​​​Could it be wiring?
Any help would be greatly appreciated!
Old Nov 28, 2022 | 05:21 PM
z31freakify's Avatar
z31freakify
If the bolt is snug and didn't pierce thru the timing cover your good.
Check wiring .
Old Nov 29, 2022 | 08:44 AM
knottyrope's Avatar
knottyrope
open the loom and start pulling on the wires, when you find one that stretches, you found a break in the wire that needs repairing
