Sponsored by: Real Truck
Bad BCM?
Old Nov 27, 2022 | 11:03 PM
txazguy's Avatar
txazguy
Angry Bad BCM?
As the title says, I'm wondering if my BCM is bad. Here are the symptoms:
2015 F250
-Driver door will LOCK but not UNLOCK. (Tried a new lock solenoid, same issue).
-Front right turn signal is INOP. (zero voltage to the turn signal wire, parking lamp gets ~12v)
Everything else on the vehicle works.... Looking at the schematics, I can see that both of those trace back to the BCM with no relay that can be changed.
Is there anything else I can try? Or do I need to go ahead and replace the BCM? If it needs to be replaced, has anyone been able to do it with forscan? I did find a guy locally that will program it for ~$250 at my house, said it would take about 30-45 min.
Old Nov 28, 2022 | 07:41 AM
projectSHO89's Avatar
projectSHO89
You first need to scan the BCM with Forscan or other capable scan tool. Guessing based only on symptoms is usually sub-optimal.
There are certain electrical faults that have to be reset via tool (after repair) anyway. Besides, even if you do determine that the BCM is in need of replacement, you're still going to need the scan tool capability for PMI unless you take it to a dealer or competent shop.
06F250superduty
Jul 31, 2020 08:33 PM
Django.Amadeus
Jan 10, 2016 11:05 AM
screamin gt
1997 - 2003 F150
Jan 3, 2011 01:17 PM
tcoates
Apr 5, 2007 11:13 AM
cliebold
Jul 24, 2002 04:25 PM
