DUI timing issues need suggestions pretty please.
Old Nov 29, 2022 | 07:56 PM
wwhite's Avatar
wwhite
Nope, thrusts down on the block.
When the gear is properly installed, the cut on the gears and the direction of rotation will pull the distributor gear down against the support (distributor gear thrust face) in the block.
Old Nov 29, 2022 | 07:59 PM
Koolminx's Avatar
Koolminx
OK then how in the hell is this thing Bayside on 14° yet after using the throttle it’s 46° higher even if I turn the idle down to 500 with a screwdriver and this is all with no vacuum.
I was thinking that with the clockwise rotation that it would pull the distributor gear down instead of up, which is why I am freaking confused, but I’m going to measure all the slop anyway as soon as the snow melts off my hood.
Old Nov 29, 2022 | 09:27 PM
wwhite's Avatar
wwhite
Why don't you complete your setting of timing including with vacuum?
Is the vacuum advance also adjustable on that unit?
rev the engine, mechanical advance hits, let off throttle, timing will not drop under 18/20 degrees.
You don't have any vacuum to pull it back.
Old Nov 29, 2022 | 10:24 PM
Koolminx's Avatar
Koolminx
initial timing on a ford is Never done with vacuum hooked up.
so I’m not going to run vacuum to it until I find out why it jumps so far and will not drop back until shut off.
Old Nov 30, 2022 | 05:26 AM
Mudsport96's Avatar
Mudsport96
unless ford is different than everything else ive ever worked on, vacuum advances timing. Not pulls it back to zero. Because this is a gm "style" unit i will think it is the same. So adding vacuum while trying to time, will add degrees to idle. That is why i suggested using a ported source for vacuum in my earlier post.
And since vacuum advances timing, and more timing gives more rpm, and more rpm give more mechanical and pulls more vacuum, you get more timing...it becomes a vicious cycle. Never use manifold vacuum for advancing timing.
If you have a 750 idle you have a given amount of vacuum and therefore a certain advance. You go from park to reverse/drive and rpm may drop and so does vacuum. Timing falls and no you have potential for a stall.
Old Nov 30, 2022 | 05:59 AM
Koolminx's Avatar
Koolminx
Base idle is set Before ANY vacuum is applied. I’ve been repairing cars for decades, I’ve been ASE certified (ex wife bitched about no credentials) since 2004 picked up at UC Berkeley..
but this distributor has be by the Ballz. I have properly timed thousands of Chevrolet’s and ford vehicles throughout my career, but this one bugs the **** out of me
Old Nov 30, 2022 | 09:33 AM
Mudsport96's Avatar
Mudsport96
it may be poor tolerance inthe distributor itself. Might have to go to an older style ford unit
Old Nov 30, 2022 | 09:34 AM
Koolminx's Avatar
Koolminx
Though of that possibility. I’ll be calling the maker this week to discuss the issue, since I didn’t buy the distributor I can’t warranty it out.
Driverjoe92
Feb 11, 2022 07:09 AM
Kramercd
65
Oct 29, 2020 11:18 AM
acfd
Large Truck
25
Feb 17, 2015 07:29 PM
1986F150six
Aug 28, 2012 12:46 PM
Bart8109
Jan 16, 2009 02:02 AM
