HO2S code help
Old Nov 13, 2003 | 06:17 AM
oldstylefseries's Avatar
oldstylefseries
HO2S code help
Fellas,
Been going crazy chasing a problem on Pop's '96 4.9Liter, E4OD.
Getting codes for the Heated O2 sensor circuit (HO2S) for BOTH O2 sensors. Replaced them both. I have the fortunate good lulck to have access to a Ford Star tester. Shows that the heater circuit works sometimes, and sometimes not. The fuse is fine as the heater circuit fuse is on the same circuit as the backup lights. Anybody else ever had this problem?
Thanks.
Old Nov 14, 2003 | 09:44 PM
kipit's Avatar
kipit
yes I have .check the connecter behind the right head,may be corroded .found this on a customers truck.check the connecters at the o2 sensors also for corrosion
