Carrying capacity
Old Nov 21, 2022 | 09:23 AM
RandyinTN's Avatar
RandyinTN
Carrying capacity
2022/23 Lariat with ultimate package, 5th wheel prep, F350, SW, 4x4, crew cab, long bed, 7.3 gasser
Rough guess as to what the door jam sticker will say?
Old Nov 21, 2022 | 09:25 AM
redford's Avatar
redford
FTE Leadership Emeritus
SRW or DRW?
Old Nov 21, 2022 | 09:44 AM
RandyinTN's Avatar
RandyinTN
Single wheel, knew I forgot something
Old Nov 21, 2022 | 09:46 AM
Split rims's Avatar
Split rims
3753 lbs. ?
Old Nov 21, 2022 | 10:14 AM
Devil's Advocate's Avatar
Devil's Advocate
4000 lbs...
DA
Old Nov 21, 2022 | 10:31 AM
4wd6.7L's Avatar
4wd6.7L
Unless the GVWR numbers changed for 2023, a CCLB 7.3l could have up to 11900 GVWR. Curb weight around 7700lbs would give it a 4200lb payload capacity. Should be close to that.
Old Nov 21, 2022 | 10:37 AM
Devil's Advocate
Ok,
How about a payload guesstimate for a 7.3 gasser CCSB tremor with Lariat Ultimate package including a 5th wheel prep?
DA
Old Nov 21, 2022 | 10:53 AM
4wd6.7L's Avatar
4wd6.7L
Originally Posted by Devil's Advocate
Ok,
How about a payload guesstimate for a 7.3 gasser CCSB tremor Lariat Ultimate 5th wheel prep?
DA
In 2022 that's about a 7400lb truck and GVWR would be 10k F-250 or 11300 F-350. We don't know how light or heavy the 2023 will be and both GVWR’s could have increased, in fact I think they have.
Old Nov 21, 2022 | 10:56 AM
Devil's Advocate
Originally Posted by 4wd6.7L
In 2022 that's about a 7400lb truck and GVWR would be 10k F-250 or 11300 F-350. We don't know how light or heavy the 2023 will be and both GAWR’s could have increased, in fact I think they have.
My F350 order sheet states 11,400 for GVWR.
DA
Old Nov 21, 2022 | 11:19 AM
4wd6.7L's Avatar
4wd6.7L
DA
In that case, 7400 might even be a little little light on my '22 estimate with 5th wheel prep and optioned out, the '23 might even be heavier so....my guess would be 3850lb capacity (+/- 100lb).
Old Nov 21, 2022 | 12:01 PM
redford's Avatar
redford
Somewhere is the 4000 lb area code.
Old Nov 21, 2022 | 01:00 PM
Dbarrett38's Avatar
Dbarrett38
I'm at 3812lbs with those specs. I'm rated at 11400gvwr I believe.
Old Nov 21, 2022 | 05:12 PM
mcmurm's Avatar
mcmurm
Agreed. My 2021 Platinum with the same specs except it's diesel has a payload of 3980.
Old Nov 21, 2022 | 05:58 PM
Grass Lake Ron's Avatar
Grass Lake Ron
Close to 4200 lbs. My SCLB 350 is 4741. I'm guessing the lariat ultimate takes off 400 lbs.
You know this is like the price is right. So if I win is it the new washer/dryer combo or the trip to Acapulco?
Old Nov 21, 2022 | 09:18 PM
jghaviland's Avatar
jghaviland
GVWR: "A Butt Load"
