Rear Hatch struts
Old Nov 18, 2022 | 06:44 PM
2002Limited's Avatar
2002Limited
Rear Hatch struts
I am discovering all the pleasant attributes of Wisconsin winters and one of them is that my rear hatch does not stay up anymore. Does this mean I should get new struts, or is this normal in cold weather? It doesn't even try to stay up - you have to hold it up with one hand or it will crank you on the back of the head. I am assuming that they are leaky, but in its former cushy life in Miami, FL, the temps never made this an issue. If so, where can I find replacements?
Old Nov 18, 2022 | 07:45 PM
96firephoenix's Avatar
96firephoenix
there's plenty of options on amazon, but these are the ones I bought:
Amazon Amazon
Old Nov 18, 2022 | 08:22 PM
CRB357's Avatar
CRB357
Pretty inexpensive and easy to replace. I went with a little bit longer setup so the hatch is higher when all the way up. I'm glad I did bc now I can walk under it and not hit my head. I'm not really that tall either, just 6'1.
Old Nov 18, 2022 | 09:26 PM
4Kids's Avatar
4Kids
The Struggle Bus¯\_(ツ)_/¯
When I replaced mine, I went with the 2WD option struts. They lift the hatch up a little bit further when open.
Old Nov 19, 2022 | 07:04 AM
Dweber85rc's Avatar
Dweber85rc
I opted for a different method, I lifted the whole rig, then the oem struts work just fine!
