Tail light fuse keeps blowing
Old Nov 18, 2022 | 11:01 AM
siete7's Avatar
siete7
7th Gear
Hi guys I have a 73 f100 4x4 auto and the brake lights stop working every time i drive it around the corner. If its parked it doesn't blow the fuse. My dash lights work, turn signals and lamps work, i replaced both flashers, i replaced both bulbs. Any idea what im missing any suggestions what i should try i appreciate anything thanks
Old Nov 18, 2022 | 11:17 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
You have a hot wire in the tail light wiring harness with a worn/burnt/mice chewed spot that moves when you drove it and it grounds out and pops the fuse. Insp the wiring harness...
Old Nov 18, 2022 | 11:38 AM
1TonBasecamp's Avatar
1TonBasecamp
What happens when you turn on the four-way flashers? What about the turn signals?
What about the flashers and the brakes?
All of those use the same filament in the lightbulb, so if it’s anything between the firewall and the tail lights, it should show up using those as well.
If they work just fine while sitting, you could actually drive it a little bit with those activated and see if it still has the problem.
For example, drive down the street and if possible before the next time you hit the brakes activate the turn signal or flashers.
Old Nov 18, 2022 | 11:45 AM
siete7's Avatar
siete7
7th Gear
Thanks i will look into that today, is there any chance that the turn signal switch could be the problem? The lever is kinda loose and i've heard that could be an issue possibly interfering with brake light fuse?
Old Nov 18, 2022 | 11:48 AM
siete7's Avatar
siete7
7th Gear
I drove it last night using hazards and turn signals and is only when in motion because it can be parked and with all hazards and hitting the brake and it doesn't get blown only when driving it so i was thinking maybe the turn signal switch maybe when i move the steering wheel certain direction that something might be loose inside
Old Nov 18, 2022 | 08:16 PM
FuzzFace2's Avatar
FuzzFace2
If you want to pull the wheel and check go ahead but I dont think that is the issue.
With the truck sitting still and the lights on the blow the fuse and a helper checking when the lights go out get under the truck and start at 1 end and start moving the wire harness working your way to the other end.
Dont over look the tail light harness when moving wires.
When the lights go out & fuse blows that is the area to look for the bare wire that is shorting out when the truck is moving.
Dave ----
Old Nov 18, 2022 | 09:47 PM
siete7's Avatar
siete7
7th Gear
Dave ----
so i went through the wiring today and it looks like everything is in place today i only pulled forward like 6ft then reversed it and it blew the fuse again, i noticed the reverse lights arent working at all i get power on the fuse box but nothing on the sockets and i spliced them a little to test em before the socket and no signal at all. I will try a new turn signal/hazard switch and possibly the neutral safety switch maybe??
Old Nov 18, 2022 | 11:03 PM
tbear853's Avatar
tbear853
How did you manage to check the 4 wire harness from just above the rear axle back to the rear cross member behind the gas tank. Where my problem was.
Old Nov 19, 2022 | 08:38 AM
bronco kenny's Avatar
bronco kenny
I had same problem when I first got my truck the wires along frame had the insulation worn off in spots I just rewired everything from the cab back to rear
Old Nov 19, 2022 | 09:43 AM
Olblack's Avatar
Olblack
I believe that there is a bad ground feeding power into that system. Clean the bulb sockets, I like using a plumbers wire brush for cleaning 3/4" copper pipe, and replace them. Cheap to do and good maintenance. I've had the filament break and fall on the outside brass causing shorts.
. When I hear about electrical problems that act weird it is usually ground problems. And bad ground is the reason for most electrical problems. BTW there is a ground strap from body to frame under the driver seat. Check it. Good luck n stay positive
Old Nov 19, 2022 | 12:02 PM
FuzzFace2's Avatar
FuzzFace2
Ok you have 2 things going on here so lets look at the blown fuse one first.
If you were moving the wires (on the frame?) and it popped the fuse why would you want to change out the turn signal switch?
If the frame harness has a plug for the tail lights unplug the tail lights and do the pull test again.
If it popps it is not the tail light harness and you need to look over the wires that moved a lot closer.
For the back up lights do you have power to the switch?
If not you need to find out why and fix.
If you have power into the switch but not out then I would say the back up light switch is bad.
I have never seen a bad ground blow a fuse but the power wire to ground will blow it every time!
Dave ----
Old Nov 19, 2022 | 12:23 PM
tbear853's Avatar
tbear853
Critters like the wrap in these harness wrappings, they will chew through them.
Old Nov 20, 2022 | 11:00 AM
Olblack's Avatar
Olblack
Dave ----
I've had the filament from the positive side of a bulb fall on to the base grounding the circuit.
Old Nov 20, 2022 | 11:12 AM
FuzzFace2's Avatar
FuzzFace2
I could be wrong but I thought that is how bulbs worked?
Power to 1 side of filament and the other side to ground?
I have seen the filament fall across the other filament and cause a feed back problem is that want you meant?
I dont think I have seen that blow a fuse just pull your hair out as other things light up when they should not almost like a bad ground.
I think he said he replaced the bulbs or was that a different post from someone as I read a lot of posts.
Dave ----
Old Nov 21, 2022 | 07:46 PM
siete7's Avatar
siete7
7th Gear
Dave ----
yea i did replace the bulbs, i'm going to try unplugging the harness from the cab back and give it a go see if it stops then yea there is a problem from cab to tail lights also i will just go ahead and install new tail light wiring with new sockets and clean the grounds, i'll post back as soon as i get to it for the outcome
