Loose zf6 shifter problems
Old Nov 18, 2022 | 05:48 AM
muddslinger48's Avatar
muddslinger48
I replaced the plastic bushings with no luck. I noticed the socket that the shifter ball goes into is really loose. How to I go about tightening that socket?
File Type: mov
Old Nov 18, 2022 | 07:19 AM
Tpayne621's Avatar
Tpayne621
It's attached to the shaft with a roll Pic. Can't tell in the video but does the shaft it's attached to move like thst also or just the cup?
Old Nov 18, 2022 | 07:37 AM
Kwikkordead's Avatar
Kwikkordead
The detent spring has failed internally, I believe. Looks like an internal repair is coming up. Nothing you cannot live with the way it is, just have to learn to shift with it as is.
Old Nov 18, 2022 | 07:54 AM
muddslinger48
Yes the shaft the socket it riding on is moving too.
Old Nov 18, 2022 | 08:16 AM
Tpayne621's Avatar
Tpayne621
Hmmm. Pull out the shift detent ball and check it. I can't remember which side it's on but it's a big bolt looking thing can't miss it. Has a spring and ball built into it. Pull it out and make sure ball still had good pressure on it. It's either that or soemthing internal with the shift rails.
