Sponsored by: Auxito
4.6 cam install
Old Nov 17, 2022 | 11:14 PM
Oldude98's Avatar
Oldude98
6th Gear
4.6 cam install
I知 going to install a set of cams in my 99 f150 4.6. I知 replacing the cams obviously, the valve seals, timing chains and components, oil pump, head gaskets. Do I need to replace the crank and rod bearings and put new rings in since I知 redoing the top end?
Old Nov 18, 2022 | 03:53 AM
manicmechanic007's Avatar
manicmechanic007
No
There are instanced when it may be warranted
Butt pot of miles etc.
Better off removing the engine for an overhaul in those cases
Old Nov 20, 2022 | 06:15 AM
STOFFERJ's Avatar
STOFFERJ
are these cams compatible with the factory valve springs and retainers???
I壇 replace the timing chains, tensioners and guides as well
Old Nov 20, 2022 | 06:06 PM
Oldude98's Avatar
Oldude98
6th Gear
I知 replacing all the timing components while I知 in there. I have new valve springs and retainers.
Old Nov 20, 2022 | 06:09 PM
Oldude98's Avatar
Oldude98
6th Gear
No
i considered putting new bearing in the crank and in the rods with new rings but if the cams weren稚 going to hurt the bottom end I was going to wait on rebuilding the bottom end for right now. The truck is just a daily driver no racing or hard towing. I知 going to pull the motor out to do everything and tear everything apart.
Old Nov 20, 2022 | 11:18 PM
Oldude98's Avatar
Oldude98
6th Gear
I知 wanting to put in comp cams xe268h cams. I知 wondering if anyone knows if there will be any ptv issues. It痴 4.6 non pi. I致e seen on some forums and videos where some people didn稚 have any issues or had to degree the cam
Old Nov 21, 2022 | 08:28 AM
STOFFERJ's Avatar
STOFFERJ
ummmm
has you had this discussion with your tuner?
what gears are in the truck?
I知 wondering why one would change the cams on a N/A npi 4.6 seems like a total waste of money and negates performance/drivability
Old Feb 14, 2023 | 02:59 PM
Oldude98's Avatar
Oldude98
6th Gear
I'm just wanting a little sound in my truck I've wanted cams for a while now. Just trying to get some helpful information on if i should do the bottom end, im pretty sure the motor has around 240ish.
Old Feb 14, 2023 | 09:19 PM
STOFFERJ's Avatar
STOFFERJ
cams will reduce the low end
if it were mine, I壇 do a PI head/cam/intake swap and enjoy it
Old Feb 15, 2023 | 08:03 AM
manicmechanic007
My sentiment exactly
If you want a hotrod, buy one
A screw or Turbo
Replacing the cams looking for performance is liable to be a bummer
It can be done, but the cam specs have to be close to factory, or it will run like puke
Maybe something similar to 5.4 lightning cam specs, is what I'd do if provoked
Old Feb 15, 2023 | 07:39 PM
STOFFERJ's Avatar
STOFFERJ
A screw or Turbo
the factory Lightning cams are identical to every other 2 valve PI camshaft
Old Feb 16, 2023 | 06:54 AM
manicmechanic007
What a shame
Old Feb 16, 2023 | 07:30 AM
Spotty's Avatar
Spotty
If it is a deeper growl you want, for sure, ditch the NPI and get some heads and an intake and go PI. Mustangs went form 215hp. to 260 hp. with the PI setup. I know for a fact my stock 97 Mustang GT did not have the same sound as my 2000 Mustang stock GT. Granted, the Mustangs have true factory duals where as the F150 does not so that makes a difference also. I really think you will be disappointed in just a cam swap. How about doing a true dual exhaust ( not just a reverse Y) to get some growl?
Old Feb 16, 2023 | 09:07 AM
Hit Man X's Avatar
Hit Man X
Why not go from the non PI 4.6 to a PI 5.4?
My PI 5.4 is 260hp/350tq area. That 4.6 I think was 210hp/260tq. Torque accelerates you anyway.
While 260hp is pretty lame, a good tune (I have 5star ones) an intake and a high flow muffler yield a much easier driving vehicle and gets down the road just fine.
Old Feb 22, 2023 | 04:41 AM
Fat-Old-Redneck-Dude's Avatar
7th Gear
I agree with Spotty on this one. I have a 2000 f150 4.6 V8 with almost 300,000 miles. Ive done all kinds of stuff Port and polished the TB and upper intake manifold, performance mustang fuel injectors, K&N CAI, Etc.. but without a doubt after putting on some highflow cats with true duals there isnt a day that goes by where Im not grinning like a little kid as I push the petal to the floor.
