Sponsored by: Kumho
grinding noise
Old Nov 12, 2003 | 09:58 PM
fairlane55's Avatar
fairlane55
Question grinding noise
I have a 92 F150 4wd, I am getting a grindiing noise and it sounds like its coming from the front. I have replaced bearings and checked the hubs, u-joints, axle shafts, fluid levels. made sure everything is tight, brakes and dust shields. the sound only comes at 15 to 20 mph, it is there with the clutch in or out, 4wd engaged or not, coasting or under load. I am wondering maybe it is the front end bushings going bad. the transmission and transfer case work fine. Any ideas? Stumped
