1978 - 1996 Big Bronco
Transmission Question
Old Nov 12, 2003 | 08:52 PM
jtreadway's Avatar
jtreadway
I have an 89 351w with 125K miles. My question is did ford make a 3 speed automatic in 89? When driving my bronco it only shifts 2 times. Each shift is very strong and rough. Just wondering if anyone knows?
Old Nov 13, 2003 | 12:01 AM
buckeyebronco's Avatar
buckeyebronco
I think that in 89 ford switched to the aod. 3 spd with od. could be wrong though
Old Nov 13, 2003 | 12:39 AM
bronco351's Avatar
bronco351
HI, I'm pretty sure that your Bronco has the E4OD. If you crawl under the truck it should say what it is on the tranmsission pan. Also, I beleive the E4OD is a 4-speed with Overdrive. So technically it's a 5-speed! Hope this helps.
Old Nov 13, 2003 | 12:46 AM
BroncoRoadKill's Avatar
BroncoRoadKill
I don't think they made the e40d till like 92, could be wrong tho.
Old Nov 13, 2003 | 06:46 AM
fcarruth's Avatar
fcarruth
My 89 is AOD if it matters. I THINK that Broncoroadkill is correct about the e4od coming in early 90's.
Old Nov 13, 2003 | 08:19 AM
bronco351's Avatar
bronco351
Well my 1990 Bronco has the E4OD!
Old Nov 13, 2003 | 08:40 AM
Satcom's Avatar
Satcom
1990 was the last year of the 3 spd auto trans. I believe the 4 SPD was an option until 1991 when it became the standard automatic.
Old Nov 13, 2003 | 08:42 AM
Satcom's Avatar
Satcom
http://auto.consumerguide.com/auto/u...ex.cfm/id/2158
This is the link I got the info from. Enjoy.
Old Nov 13, 2003 | 08:55 AM
Torky2's Avatar
Torky2
Every '89 351 Bronco I have seen with an automatic has been a C6. Three speed. Durable trans, highway mileage just won't be as good and drivetrain noise will be higher. But a good trans.
Old Nov 13, 2003 | 09:16 AM
bronco351's Avatar
bronco351
Yeah, but that only shows as far back as 1991. I know for a fact my Bronco has teh E40D!
Old Nov 13, 2003 | 09:23 AM
Sport45's Avatar
Sport45
Look at your transmission gear selector. If it has D-2-1 you have a 3-speed. If it has O-3-L (or somthing like that) you have the AOD 4-speed overdrive. If the "D" has a circle around it followed by the 2-1 then you have the electronic overdrive. The telltale sign for the electronic overdrive is the "overdrive off" button on the end of the gearshift lever.
Old Nov 13, 2003 | 10:29 AM
Satcom's Avatar
Satcom
Bronco351 I never said that you didn't have an E4OD, I just stated that they were optional. These electronic 4 speeds strated to appear in 1986 as an option, they became standard in 1991.
Old Nov 13, 2003 | 07:58 PM
jtreadway's Avatar
jtreadway
Thank you all for your imput it really helps. Just one more question, how difficult is it to change out the 3 speed for an e4od tranny?
Old Nov 13, 2003 | 09:21 PM
dblue351's Avatar
dblue351
Trust me keep the C6 and DO NOT put in an E40D. BIG PIECES OF CRAP.
But that is my personal opinion! Sorry if some do not agree.
Old Nov 13, 2003 | 10:54 PM
rlh's Avatar
rlh
I have a 1990 with AOD. On the indicator it has a D with a circle around it, a D, and a 1. I thought the C6 was not used after the mid 80s but a retrofit is possible.
