Sponsored by: Auxito
torsion bars
Old Nov 12, 2003 | 08:00 PM
00sc4x4's Avatar
00sc4x4
torsion bars
Hey umd how do i adjust the torsion bars and where are they is it hard to know when it is level with the rear. Does adjusting them effect the trucks handling.
Old Nov 12, 2003 | 08:05 PM
LxMan1's Avatar
LxMan1
It may stiffen it up some. Just turn them the same amount of turns so that it will not lean to one side. A tape measure will tell you when it is level.
There is a bolt near one end that when tightened, it will raise the truck.
Jimmy
Old Nov 12, 2003 | 08:12 PM
00sc4x4's Avatar
00sc4x4
where are they located on my truck lxman
Old Nov 12, 2003 | 10:00 PM
LxMan1's Avatar
LxMan1
They are the long bars that run from the control arms back to the crossmember. The are about 1" or so in diameter.
Jimmy
Old Nov 17, 2003 | 12:16 PM
Rusty1's Avatar
Rusty1
I tried adjusting mine and I hated it after. I ended up putting them back to normal and installing a 5 " lift to get what I wanted.
If you tighten the "T" bars, you'll find when you hit a bump (on the highway for example) and the truck jumps in the air you "A" arms will bottom out and bang really hard (a bad thing) . Also if you do it anyway, don't forget you must have your front end aligned or your tires will wear funny. My final comment (from experience) is you should not try tightning them.
Old Nov 17, 2003 | 03:04 PM
fx4er's Avatar
fx4er
hey Rusty, what if i want to just level out the truck without adding a 5" lift kit, and without turning the torsion bars. do they sell a lift kit for just the front that will raise it about 2" ? i think that's all i'll need to level mine out.
thanks
robert
Old Nov 17, 2003 | 05:31 PM
Rusty1's Avatar
Rusty1
Robert
I can't tell you if there's a 2" lift on the market or not (There could be). I really didn't like how my truck handled after twisting the "T" bars and my intent was to level it out like you want to do.
Another point is on the 4x4 is the angle the front drive shafts are going to have to work at if you change the geometry. You may overwork the joints.
Consiquently I decided to install the 5" kit and in that they lower everything so the drive shafts turn true and you maintain the stock suspension system or ride quality.
