Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
In truck piston replacement?
Old Nov 11, 2022 | 03:01 PM
TreeFeller's Avatar
TreeFeller
1st Gear
2002 F650 with 7.3L PS
Injector failed and ruined cylinder 4 (left, second from front). It has approx. 100 psi compression. No idea yet if it is rings or cyl wall issue.
Is it possible to pull the head, and remove the piston without pulling the motor?
Oil pan is easily removable in this truck as there is no cross member under the pan like small F series.
