Sponsored by: Auxito
buzzing noise
Old Nov 12, 2003 | 07:52 PM
hoody11100's Avatar
hoody11100
buzzing noise
Recently purchased a 97 F150... occaisionally when I hit the hazard switch and the release it (so they are now off) I get a weird buzzing noise that seems to be comming from the steering column (near the hazards).
When I turn the hazards back on, the buzz goes away. but when I turn them off, it comes back. pressing the breaks also causing the problem to cease.... Eventually overtime the noise will go away.
ideas?
Old Nov 13, 2003 | 08:31 AM
Racerguy's Avatar
Racerguy
Hi hoody11100 and welcome to FTE
It sounds to me like your multifunction (signal/wiper) switch might be on its way out. It could have a bad connection inside which is causing the buzz. I think I'd remove the covers from the steering column and see if I could pinpoint where the noise is coming from.
If the noise is coming from further down and towards the center of the truck a bit more it could be your flasher relay.
Old Nov 13, 2003 | 08:43 AM
hoody11100's Avatar
hoody11100
Thanks! I will check that out!!!!
