1996 ranger 4wd problems
Old Nov 12, 2003 | 07:49 PM
wrx700hp's Avatar
wrx700hp
My 4.0 rangers 4wd wont engauge. When i turn the switch i hear the hub lock or so it sounds but no 4wd. I figured this problem out last time i was driving on the beach. The front tires didnt spin at all just the rear.
Old Nov 12, 2003 | 08:49 PM
Dealford's Avatar
Dealford
Welcome to FTE wrx700hp. I'm not a 4x4 expert, but do you use the 4x4 often? It may be time to rebuild the front hubs?
Old Nov 13, 2003 | 07:30 PM
stRanger706's Avatar
stRanger706
Re: 1996 ranger 4wd problems
do you know if the 4wd is actually engaging (transfer case)? can u see the front driveshafts turning? if so, then dealford is right. your auto-hubs probably broke.
