Which Speedo Gear
Old Nov 9, 2022 | 06:27 PM
fpt2's Avatar
fpt2
Which Speedo Gear
The previous owner put larger tires on so now the speedometer/odometer is off. The rear axle code is H3 and the tires are 30" How many teeth would my speedo gear need to be in order to get an accurate reading?
Old Nov 9, 2022 | 07:29 PM
351Cleveland C4's Avatar
351Cleveland C4
You have to see what gear it has, and how much the speedo needs to change.
Each tooth makes about a 2mph difference. Subtract teeth to increase speed, add teeth to slow it down.
Old Nov 10, 2022 | 06:05 AM
fpt2's Avatar
fpt2
Thank You!
Old Nov 10, 2022 | 07:50 AM
diggerrigger's Avatar
diggerrigger
FWIW: I ran 30" tires for years on my Truck. The difference from stock was 5mph @ 55. Speedo read 55 but truck was actually doing 60. (Axle 19, 3.55:1)
GM4WALLS
Apr 3, 2016 03:11 PM
RangerHaywood
17
Aug 17, 2010 08:29 PM
boogity24
Aug 10, 2004 08:10 PM
slifer
Sep 10, 2003 10:30 AM
