79 ford inner fender ques
Old Nov 12, 2003 | 07:10 PM
CrashMaster's Avatar
CrashMaster
I have a 79 f150 short bed. The dude i bought it off of must have taken out the inner fenders. (the plastic covers inside the fender)Im afraid that this will cause the cab to rust out due to no protection from water and road salts. My ques is. Will the front and rear inner fenders off of a regular(8ft bed) fit on my truck?
Old Nov 12, 2003 | 07:14 PM
BigBully's Avatar
BigBully
Are you talking about the front? If so then Im pretty sure they are the same from whatever year they started to 1979 models Short bed, long bed sould make NO difference on the front fenders.
Old Nov 12, 2003 | 07:28 PM
CrashMaster
both front and rear.
Old Nov 12, 2003 | 07:36 PM
Mil1ion's Avatar
Mil1ion
Called : Inner Front Fender *Liners*
Old Nov 12, 2003 | 10:42 PM
Torque1st's Avatar
Torque1st
Posting Legend
The fronts will fit but the rear may or may not take some fitting. Hope you get lucky.
Old Nov 13, 2003 | 01:01 PM
highboy 74's Avatar
highboy 74
Smile
I had my inner fender wells coated with a spray on bedliner. It makes them impervious to rust and the elements. I believe this is the best way to protect your inner fenders. It is fairly cheap also. It only costs about 25 bucks per fender. It also deadens sound as well.
Old Nov 13, 2003 | 08:34 PM
theonlybull's Avatar
theonlybull
put in a set of fronts, then get another set of fronts, and cut them down to work in the rear, they will give you much better protection then the factory rear ones... they arn't hardly worth putting in there
