EMERGENCY- HELP
Old Nov 9, 2022 | 02:43 PM
Icculus's Avatar
Icculus
EMERGENCY- HELP
EMERGENCY- a side of my steering linkage popped off. Somehow, don’t know wtf happened. I’m stranded in a outlet mall parking lot. Need to know the threading size of this bolt so I can get a replacement to make it home 02 7.3
Old Nov 9, 2022 | 02:59 PM
ESwift's Avatar
ESwift
CNCFAB
If memory is correct they are m14 x 1.5
Old Nov 9, 2022 | 03:27 PM
knottyrope's Avatar
knottyrope
looks like you picked up something and it hit the nut to make it loose. your rim has some severe gouges in it and tire looks like it took some damage too
i see rust on the threads, i dont think the nut was on there for a while and what ever was in there popped the taper off
Old Nov 9, 2022 | 05:20 PM
Icculus's Avatar
Icculus
for anyone that searches this in the future it is a m14x1.5
lowes didn’t have it. Had to go to ford.
now I have to find a taper and a actual castle nut as ford only had a nut, not a castle nut
Old Nov 9, 2022 | 09:26 PM
Icculus's Avatar
Icculus
I’ve had the truck for over 50k miles. Never touched that area other than shooting some grease in there. You must be right
Old Nov 10, 2022 | 06:34 AM
Walleye Hunter's Avatar
Walleye Hunter
Can't you cut some notches in the nut you got with a cutoff wheel? If you really need it, I could probably find one in the garage and send it to you.
Old Nov 10, 2022 | 07:54 AM
Kwikkordead's Avatar
Kwikkordead
I've NEVER seen one of those fasteners come off on their own unless it was never tightened down in the first place, or this truck was involved in a dispute with the former owner and someone did some work on it in the middle of the night.
Old Nov 10, 2022 | 08:00 AM
FordTruckNoob's Avatar
FordTruckNoob
At this point, check to see if the hole for the tie rod end in the knuckle has been wallowed out from the tie rod end wobbling. If it is, no amount of tightening a nut on it will keep it from moving around.
Old Nov 10, 2022 | 09:12 AM
RacinJasonWV's Avatar
RacinJasonWV
Don’t tie rod ends come with new nuts? Just an idea if you’re having trouble finding a new castle nut. They aren’t typically that expensive (although much more than just a nut). You could use the nut from the new tie rod and throw the new end in the spare parts box.
Old Nov 10, 2022 | 09:27 AM
z31freakify's Avatar
z31freakify
Just by looking at it looks like it hasn't had a nut on there for a while judging by all the rust on the threads. You can get away by using loctite, or if the nut that you installed has that nylon locking threads.
Old Nov 10, 2022 | 10:02 AM
knottyrope's Avatar
knottyrope
you are lucky it didnt fall off when at a higher speed
Old Nov 10, 2022 | 01:06 PM
Walleye Hunter
Is the tie rod end loose in there or is it still jammed tight?
VA13FX4
Aug 14, 2020 11:23 PM
Silverhks
May 31, 2018 09:22 AM
69-er
Apr 7, 2018 01:13 PM
Dace
May 10, 2014 07:41 PM
obscurity
Jan 4, 2014 06:15 PM
