2 questions
2 questions -
My 93 F-150 ith 133,000 miles is leaking pretty heavily from the steering box at the pittman arm shaft seal.
In a bind, I had added some Dexron III ATF Fluid instead of the Ford recomended fluid to top off the PS fluid . Has anybody had any experience with intermixing fluids causing seal problems???
Also, truck has devoloped a skip in engine that is only noticable when engine has warmed up. Sounds OK when motor is cold.
Sounds like a fuel problem to me, anyone have similar problems?
Thanks for any help, I've owned this truck since new in 1992 & hope to get another 11 years out of it!!
Joe
