Why Ford, why?
The first time a lug nut failed I was perplexed as to why every nut I got at the parts store wouldn't fit. Even though it's an 03 I figured "let me try using one from an 01", found the solution.
The axles were never replaced so this was a factory mess. When I replaced the hubs, sure enough 2.0 thread was the only one availble. Imagine going to have your tires changed without knowing this & the guy mixes up the nuts then tries to impact them on.
Another one I'm trying to figure out is the front outer axle shaft seal "redesign". I'm unsure if this is on Ford or retailer scumbaggery but the metal cup that sat on the 60 (not super 60) shaft between it & the seal, some places say a redesigned seal eliminated this, some such as ventures say "some come with it, some don't."
Well that doesn't help.
Most 60 axles I've seen have that press fit metal cup torn to crap by dingbats who either didn't install or uninstall the shaft correctly when doing a u-joint. Mine was filled with prybar holes dooming any future seal to be torn as soon as it was installed.
Looking for a replacement seal just becomes irritating when met by the redesign answer. When they show the redesign, they show something for a super 60, not a regular 60.
https://www.rockauto.com/en/catalog/...ing+&+hub,1636
Oddly enough when ordering replacements the 5.4/4x4 SRW combo called for 2.0 coarse, I believe the 1.5 threaded ones I could find noted DRW only.
