Bronco II Ford Bronco II
speedometer
Old Nov 12, 2003 | 11:55 AM
Bronco2's Avatar
Bronco2
speedometer
my bII's speedo stopped working i think its the speedo cable . it started bouncing and wouldnt tell me the right spped then it just fell and wont get back up thoughts
Old Nov 12, 2003 | 08:05 PM
87 XLT's Avatar
87 XLT
If the cruise control isnt working either, pull the speed sensor out of the trans. & check for a broken plastic gear. Very simple to replace.
Old Nov 12, 2003 | 08:16 PM
plilikoi's Avatar
plilikoi
It could also be the drive gear, or the gauge.
Best thing to do is to pull the speedo cable and take a look at it. To do this you need to gain access to the back of the instrument panel. Disconnect the battery and remove the dash components surrounding the instrument panel. With the instrument panel loosened you can reach behind it and press the quick release holding the speedometer cable conduit. With the conduit detached from the back of the instrument panel you should see a piece of white plastic. Grab hold of this and gently pull the cable out. If it's obviously damaged you'll have to replace it. To replace it, clean and lube it (with cable lube) then push it back into the conduit, twisting as you go to ease it on its way. At the end make sure it engages the drive by twisting it a full turn. It should drop about 1/2 inch into place.
It's really easy to do this, just a bit time-consuming to remove the instrument panel.
Does the odometer still work, by the way?
Old Nov 13, 2003 | 08:21 AM
Bronco2's Avatar
Bronco2
i dont have cruise control and no the odometer stopped working about 5 months ago before i left for port call
Old Nov 13, 2003 | 12:24 PM
plilikoi's Avatar
plilikoi
It sounds like the cable or gear then.
I recently pulled the speedo. cable on my BII because the speedometer was becoming increasingly erratic, after being noisy for some time. The cable seemed to be binding when I removed it. I cleaned and lubed it, put it back, and it seems to be okay now. It still fluctuates a little around 10-15 mph, but before cleaning it would jump between, e.g., 75 and 85 mph when I was cruising at constant speed.
Old Nov 13, 2003 | 08:07 PM
Bronco2's Avatar
Bronco2
ok
hey thanks for all your help
Old Nov 13, 2003 | 09:05 PM
reddeer52's Avatar
reddeer52
Familliar problem. My BII speedo seems to be reading about 5 mph high up to 45 mph. I'm not sure if this value stays the same above this. I checked my speed with one of those portable speed traps many cities setup. Would this likley be the cable, (since it does jump sometimes), or mite the gauge itself be defective? 1985 BII, 2.8L, 4x4
reddeer52
Old Nov 13, 2003 | 09:16 PM
plilikoi's Avatar
plilikoi
Are you running on small tires?
Is the odomoter recording distance correctly?
I would go ahead and clean/lube the cable. It probably could use the attention. I procrastinated doing this for a long time, but it turned out to be really easy.
If you know the cable's OK and the odometer is correct then the gauge is likely at faut.
Old Nov 14, 2003 | 07:53 PM
Oceanwave's Avatar
Oceanwave
Bronco 2: Check the drive gear. My speedo did the same thing as yours and then died. I replaced it and it was still bouncing around until I replaced the tranny end gear.
Stephenhutto
1997 - 2003 F150
Dec 20, 2009 04:33 PM
adelyser
1978 - 1996 Big Bronco
Oct 10, 2002 01:48 PM
msalvetti
Jan 19, 2002 12:51 PM
73Custom
Jun 6, 2001 08:16 PM
PAUL_2
Oct 29, 2000 11:30 PM
