PLEASE HELP!!! with NO RUNNING LIGHTS
I need some help finding out why "ALL" of my exterior running lights are not working, all interior lights seem to be OK. I will explain what happened when this problem started and what I have checked to try and correct it. I have a 2011 F450 Lariat I purchased used and everything has worked great for almost 2 years now. So I installed my Arctic Fox camper and my Trailer to pull a SxS, I had to do a little minor wiring and clean up connections, all lights worked great no problems for a couple of weeks then we went on vacation and lost all of the running lights on exterior of the truck, camper and trailer 1 day into the trip, the brake, turn and flashers still worked fine, drove 2 more days in daytime only until I got to my sons house to work on it. So I went to interior kick panel Fuse #30 (Parking lamp relay, TT parking lamp relay) the fuse was good but had NO power to it at all , so I went to fuse box under hood and checked Fuse #26 (Trailer tow park lamps) No problem found, Swapped Relay #29 (Trailer tow park lamps) with one that worked, still problem not corrected, looked around best I could for a wiring issue and found nothing so I decided to power the camper and trailer running lights using the unused Upfitter switches #1 and #2, I ran wires to camper and trailer. In the process, by mistake I connected the camper lights wire backwards and back fed to the truck, "ALL" of the exterior running lights came on, I knew that was a mistake so I installed it correctly. All camper and trailer lights worked great using the upfitter switches.
Note; When I back fed the camper light wire into the truck all of the running lights came on and I was not able to turn them off using the light switch or key so I disconnected the battery, then reconnected battery and they stayed off, so this screw up proved all the bulbs work and I could power all the running lights from the plug in the bed of the truck. The camper and trailer are off the truck now and nothing changed.
Right now I'm at a loss at what to check next and could sure use some advice or ideas.
Thanks!!!
Wish I could add more as my truck is 2002. Not sure what's what's dash.
But I have a whole subsystem for the 7 pin with a few fuses and relays.
Go see this post: https://www.ford-trucks.com/forums/1...nce-lamps.html
Altthough the OP never followed up, there's a lot of information there, especially schematics, that may help you move further long.
C'mon back here if you have additional questions.
FYI, I found a company in NY that states that they can repair my BCM with a 1or 2 day turnaround for $255, they also state that if they find no problem they will return it to me at no charge $0, I'm sure I'll have to for pay shipping both ways at probably around $80 or so, they also say that NO reprogramming is required because it's my old unit, does anyone know about this company or to these claims.
