I have a 2021 platinum and I’m having difficulty setting the climate control with respect to the remote start. The manual indicates that I need to go to the touch screen settings, vehicle, remote start settings, unfortunately after the vehicle icon I do not have a remote start settings icon.
However i do have remote start.
Any help would be appreciated.
Are you looking at the center stack screen or the dash screen?
The setting for it is in there, been a while since I set mine up, can't recall which screen.
Remote start climate settings are found in the settings menu in the cluster.
Yes, instrument cluster, not the center stack. on my XLT Premium anyway. I do not have a remote start fob, only via Ford Pass which works for me.
Under vehicle settings, remote start, climate (IIRC) you have a choice of automatic or last settings. I have mine on "last settings" which means in the summer I set the A/C to full blast, and in the winter I set the defrost to full heat/full fan. This must be done before you shut off the truck, as you are leaving. It's taking me a while to remember to do the set up, as I have never before owned a vehicle with anything like this capability.
