Take Off Wheels and TPMS
Old Oct 22, 2022 | 11:22 AM
HRTKD's Avatar
HRTKD
Originally Posted by aklim
Bottom line is THIS is what I need. IF it is, then that is the part number I can go for. Tire Rack sells THAT which is definitely cheaper and will work. Or I can go to Amazon and buy it HERE. Anyone see anything I should do different? TIA
Thankfully, the tires are wearing to the point I have to change them and this is a take off set with 300 miles on it but no TPMS.
The last link you provided is no-name knockoff. Never heard of them even though they reference the Ford part number.
Old Oct 22, 2022 | 03:45 PM
aklim's Avatar
aklim
What is the difference between the programmable ones and non programmable ones?
Old Oct 22, 2022 | 03:55 PM
HRTKD's Avatar
HRTKD
Guys that are setting up winter and summer tires/wheels/sensors will find it easier to use the programmable sensors. It allows both sets to look exactly the same the truck. No need to go through a relearn.
If you have only one set of tires/wheels/sensors then programmable isn't that useful.
Old Oct 22, 2022 | 08:39 PM
aklim's Avatar
aklim
Supposedly Rock Auto has the Schrader one for $21.79 HERE. Thoughts? It is a non programmed one at 315 MHz and I am not swapping tires or wheels. Just bought THIS so should be good for a while. Dismount the old ones and try figure out what to do with the good condition 18 inch wheels when I get back from an overseas trip.
Old Oct 22, 2022 | 10:58 PM
HRTKD's Avatar
HRTKD
Sounds like a good price on a high quality sensor. As long as it is spec'd to work with your truck, go for it.
2002 ford
1997 - 2003 F150
May 2, 2021 09:13 AM
Warhound
Apr 20, 2018 01:59 PM
Olds69442
Ford Truck Parts for Sale
May 24, 2016 08:08 PM
f4fran
51
Apr 24, 2008 10:13 PM
