Bronco II Ford Bronco II
wheel alignment on BII
Old Nov 12, 2003 | 11:20 AM
greenlx91's Avatar
greenlx91
i"m a mustang guy so bear with me on this bronco II stuff. i have a friend who's truck i will be replacing ball joints on. i havent even looked at the thing yet, but does anyone know (or where i can find info) how to set the camber on these trucks? do you use shims, where do you put them etc.. thanks in advance!
Old Nov 12, 2003 | 04:25 PM
mrshorty's Avatar
mrshorty
Camber is adjusting using a bushing on the upper ball joint. There are various bushings available (in 1/2 degree increments, I believe) depending on how much adjustment is needed. A manual that talks about ball joint replacement should at least make mention of the camber adjuster bushing.
ManfredVonRichtofen
Mar 21, 2017 01:06 PM
brian1080
Mar 21, 2016 07:08 PM
351Cleveland C4
89
Sep 12, 2015 10:13 PM
EJL96PSD
Colorado Chapter
May 21, 2006 12:06 AM
xplict
Apr 21, 2005 01:35 PM
