Steering difficulty
Old Oct 20, 2022 | 07:15 PM
ThorsRide's Avatar
ThorsRide
4th Gear
Steering difficulty
My steering has been getting more and more difficult. Its at the point where it is near impossible to turn. My son replaced the pump, but the problem persists. Any thoughts on how I can determine what needs fixed or replaced?
Thank you
92 F250, 460 xlt. No mods other than a snow plow.
Old Oct 20, 2022 | 08:42 PM
Prototypemech's Avatar
Prototypemech
You can jack the front of the truck off the ground and turn the steering wheel with they engine off. If it's easy to turn, than it's a power steering problem, not a mechanical/binding problem.
There's only 3 parts to the power steering system; the pump, the gear box, and the hoses.
I imagine your son replaced the fluid when he changed the pump, so no need to flush the system.
The only thing left is the gear box.
Old Oct 20, 2022 | 11:56 PM
TooManyMIce's Avatar
TooManyMIce
If it's still stiff with the engine off, while you've got the front end in the air, see if you can wiggle the front wheels by hand (steering, not rotation). If one moves, and the other does not, you could have a ball joint or U joint or something seizing up on that side. If they're both too tight to tell, you could pop the tie rod ends out and make sure both knuckles swing. If the knuckles move freely, and the tie rod ends are okay, but the steering is still hard to turn, that leaves the box or the column.
If you adjusted the box at some point to try and get rid of steering play, you may have tightened it too much. I did that on a Nissan once. It felt okay at first, then got harder and harder until I was having to really reef on it to make it turn. By then the adjuster was stuck. I replaced the whole assembly, unfortunately with a crap reman that had more slop than the old one had before I tried to make it better.
Old Oct 21, 2022 | 12:54 AM
AuroraGirl's Avatar
AuroraGirl
Thank you
excuse me did you just say no mods other than a snow plow :O
How heavy of a snow plow is this, and does your truck have any non-OEM tire size , any extra welding on such as brackets or braces. does the truck run fine?
When idling, does your steering get easier if you jab the throttle? Does your enging bog down when turning? (at idle)
in my opinion, its likely to be weight on the front end, wear or grease needed on steering pivots, larger tires, debris /blockage in the pump/fluid as well as a random part store pump having the incorrect flow control valve.
Did your trucks OE pump, did it work at all better or do you still have it by chance?
Old Oct 21, 2022 | 12:56 AM
AuroraGirl's Avatar
AuroraGirl
I would not be too quick to discount the fluid, a pump that was dying or a debris-filled system is a great way to have a blockage that only shows itself at low speed/not moving.
But i think that would also depend on if the pump replaced was the OE or not
snglspeed
Mar 19, 2017 05:06 PM
landscapeguy
Aug 6, 2016 07:14 AM
greggara
6.7L Power Stroke Diesel
17
Jul 6, 2011 05:03 PM
There Goes The Neighborhood
Mar 5, 2005 07:23 PM
Raf20
Mar 19, 2004 08:05 PM
