High beam location
Old Oct 13, 2022 | 09:33 PM
OBSRAVONA's Avatar
OBSRAVONA
High beam location
I have a 1994 f150 but I have no idea how to turn on high beams, the headlight switch just has normal lights.
Old Oct 13, 2022 | 09:38 PM
Prototypemech's Avatar
Prototypemech
Push forward (away from the driver) on the turn signal stall for high beams. Pull back on the turn signal stall for 'flash' (high beams and low beams)
Old Oct 13, 2022 | 09:39 PM
OBSRAVONA's Avatar
OBSRAVONA
Okay sweet thank you.
Old Oct 14, 2022 | 07:11 AM
AuroraGirl's Avatar
AuroraGirl
Came from older vehicles, eh? your truck also has FLASH-TO-PASS feature, which may actually be law in your state(its not mine, no one hardly ever does this for passing on the road) but it is the opposite direction you pull the lever(instead of push away) it will light the high beams until you let go. So good tip if you ever encounter a switch that wont stay in high beam, try the other way. My car, for example, you pull the lever till it clicks, then let go, flash to pass is done by lightly pulling. pulling again will turn it off
Old Oct 14, 2022 | 08:52 PM
Mudsport96's Avatar
Mudsport96
Originally Posted by AuroraGirl
Came from older vehicles, ehh?
Like my daughter, her first car was my Nova.
Stomp button on the floor lol. When she got the newer Silverado from her grandfather, she was lost on how to turn on the brights.
Old Oct 14, 2022 | 08:57 PM
AuroraGirl's Avatar
AuroraGirl
my first car had the column switch, but even tho im young I actually learned about the button first because my dad had a 75 dodge and still a 75 gmc that had the floor button. Then I got a 77 LTD , floor. Then my square(1980 gmc), floor. I like the floor button tbh.
My 1975 grand am rotting in the field has the first stalk high beam in the US i believe, that model year or gen iirc
ITSOT
Oct 22, 2017 05:17 PM
senatordan39
Oct 31, 2016 03:51 PM
texasJ
2004 - 2008 F150
Aug 8, 2014 11:27 AM
Millbrook_Dawg
Jan 29, 2004 03:30 AM
seachris1965
Nov 2, 2002 01:35 PM
