Instrument Cluster Power Issue
If you note the point it connects to the switch in the diagram, it's listed as the Prove-Out position. That's the traditional (pre-computer) lamp test. The ignition switch grounds it to the dash when the key is turned to START.
Then the lamp goes back to dormant when the key is released.
Power for the lamp probably comes in from the #932 wire from the switch. That could be a common wire with the instrument cluster, but I can't see it all in the diagram especially with some of the corners cut off and on the smaller screen (that's a "my poor eyes" issue, not yours!) so not sure I'm following all the circuits correctly.
But I think that's correct.
Regarding the cluster regulator, you can't really measure ohms (or at least it takes a specialized method) and you probably would even have trouble measuring voltage using a digital volt meter. With an old analog meter with a needle you can see the needle pulse regularly between about 4v and 8v or so, averaging out to somewhere between 5 and 6 volts if I remember.
It's an electro-mechanical thermally compensating regulator. Only with a modern electronic version will you see a steady voltage output.
So you may have replaced it unnecessarily, but then again it's still hard to say.
Oh, and the diagram we're using here is for the alternator indicator lamp type. Didn't you say earlier you had an ammeter? Sorry if I'm remembering that incorrectly. I'm going to go re-read it, but with so many interruptions in my daily life, I never seem to be able to do anything in just one sitting!
It could mean, as usual, multiple things.
1. It could indicate that the gauges are not receiving the power from the regulator.
2. It could indicate a bad connection between each gauge and it's sending unit.
Those could be bad wires, bad connections, bad grounding method, or bad components still. It's not unheard of (or even unusual anymore) to get several bad ICVR units in a row. The instance of bad parts right out of the box is a rampant issue at the moment. So you can't just replace parts and assume they're helping solve the problem anymore.
Just to help me out, refresh my memory about whether you have the battery charge indicator lamp, or the ammeter.
It might be the case that both types use the same wiring at some points, but it would be standard practice by Ford if connection points in the cluster connector do not match between one type and the other.
Thanks!
Paul
From the diagram, the only ground in the circuit for the gauges looks to be the ground at the fuel tank sending unit. I checked that and no issue there. The only sending unit I didn't ground the wire to see if the gauge pegs was the oil pressure unit. Let's say that wire went bad for some reason. Would that cause all three gauges not to work?
How did you check the ground at the sending unit?
And no, a fault in a wire in one gauge sender circuit will not effect any of the others.
The only common thing between the gauges is the power-in from the ignition switch and the illumination power from the headlight switch. But the illumination circuit is not part of the gauge's working functions.
After the power comes in from the common source they become completely independent from each other out to their specific sending units.
The gauges are not grounded per sé. They "ground" through the sending units only. A variable ground if you will...
You need to check them all just to be sure it's still a common issue and does not just happen to be two out of the three with bad wires.
Tested for ground at the water temp sending unit by disconnecting wire at the sending unit, then using another piece of wire to extend that to ground on the radiator support (also tried the negative terminal on battery)
https://www.uniquecarsandparts.com.a...perature_gauge
The connection to the fuse panel via #297a and accessory plug via #297b are from that splice where #30 joins up. So the connection to the fuse panel is showing how the fuse panel gets it's switch power.
Same as #30, direct from the ignition switch.
Not sure what wire color will be at the cluster voltage regulator/ constant voltage regulator, but it was Black w/green on the other diagram.
And in a pinch, the standard practice for the regulators is to use an insulated/female terminal on the wire coming in with power, and an uninsulated/male terminal on the wire heading out to the instruments.
Look for that type of connector and see what you get.
Paul
The light bulb for the brake pressure differential valve could have been burnt out from a brake issue. When my 70 f250 brake light was on, I had to remove it and take it apart to get the internal rod re-centered. Then I replaced the brakes on the front and bled the brakes. It moved again while bleeding the brakes but with some driving and braking, it re-centered.
