P0170 & P0402 Codes
Old Oct 10, 2022 | 11:46 AM
craigc1264's Avatar
craigc1264
7th Gear
P0170 & P0402 Codes
I have recently purchased a used 2017 F250 6.7. I pulled the codes off Forscan. The dealership isn't able to get the truck in for over a month to even diagnose the issue. I have attached the DTC text from Forscan.
Is there anything I can do (besides finding another maintenance shop) on my end to solve the problem?
File Type: txt
Old Oct 10, 2022 | 12:10 PM
GMB Racing's Avatar
GMB Racing
P0402
One of the three basic problems that produce this error code is:
To begin, the DPFE (differential pressure) sensor may be defective and should be replaced. In this case, the problem is a defective sensor rather than a performance problem. The simplest and best-case situation is as follows.
Second, the EGR could be obstructed. This blockage is most likely caused by carbon build-up, which can happen over time as particles accumulate, but it might also be caused by something else becoming lodged in that portion of the engine.
Finally, due to a lack of suction, the EGR valve could be broken and not open.
Old Oct 10, 2022 | 12:16 PM
craigc1264's Avatar
craigc1264
7th Gear
Originally Posted by GMB Racing
P0402
I have noticed the DPF seems to fill up quickly. It will go from 60% to 75% in about 30 miles without a trailer or intense driving. Also, my miles to empty is fluctuating quite a bit. It suddenly calculated my DTE with an additional 100 miles at a half tank.
Old Oct 10, 2022 | 12:21 PM
redford's Avatar
redford
FTE Leadership Emeritus
The truck is probably trying to perform regens to clear what it thinks is a plugged up DPF. Fix the sensor first, then worry about the DTE display.
Old Oct 10, 2022 | 01:56 PM
craigc1264's Avatar
craigc1264
7th Gear
P0402
any chance you would have part numbers for those sensors and valves?
volkswitt
Jun 18, 2017 03:26 PM
a.s.k.52
6.4L Power Stroke Diesel
May 13, 2015 10:49 AM
KRATH
Apr 22, 2013 11:39 AM
