Truck Specs
Old Oct 9, 2022 | 09:52 AM
jma92114's Avatar
jma92114
Trailering
Truck Specs
Hello All,
I have a 1991 F150 XLT V8 5.0. Can anyone guide me to a reliable source where I can get my trucks 'factory' specs?
Thanks...
Old Oct 9, 2022 | 10:51 AM
sandymane's Avatar
sandymane
You can research your VIN for info. You can also look at the door jamb sticker for the codes.and Google them for info.
Old Oct 9, 2022 | 11:58 AM
jma92114's Avatar
jma92114
Trailering
Confused
Hey Sandymane,
I'm not terribly internet saavy. When you say 'research,' where would I go to conduct this research? As for codes on the door jam sticker (see below), what codes are you referring to, and where on Google should I go with them? Please excuse my ignorance.
Thanks...
Old Oct 9, 2022 | 01:29 PM
sandymane's Avatar
sandymane
An example would be to go to Google and type in "What is the 1991 ford transmission code E" Somewhere on the page it shows E is for a Ford E4OD Which is what you have and it is a 4 speed auto with OD over drive. I ALWAYS drive in Overdrive with my E4OD. The E4OD is computer controlled and when you get into diagnosing the computer it can identify transmission problem codes which is a nice feature. Always check the fluid level and fluid condition on your trans and it will serve you well if not mistreated or neglected in the past.
Go to google and type what is ford door jamb axle code 19 . that will show you have a 3:55 rear end which is a good all around gearing.
Is there anything specific you want to know or are you just curious? The second link and the 4th link in the below article allows you to find out about your VIN features.
https://www.google.com/search?q=ford...client=gws-wiz
Old Oct 9, 2022 | 01:44 PM
jma92114's Avatar
jma92114
Trailering
Thanks Sandymane.
Old Oct 9, 2022 | 07:27 PM
85e150's Avatar
85e150
This site has some good decode info, and you can put your VIN in direct if you want:
https://www.blueovaltech.com/tech/decode.php
Old Oct 10, 2022 | 11:12 AM
Conanski's Avatar
Conanski
Almost everything you need to know is right there on that decal.
GVWR = Gross Vehicle Weight Rating: The maximum weight the truck can weigh with all passengers and cargo
GAWR = Gross Axle Weith ratings: Maximum weight capacity of the axles
Trans code E = E4OD
Axle code 19 = Ford 8.8 with 3.55 open differential
Springs D 7: D = Front, 7 = Rear.
Old Oct 10, 2022 | 11:39 AM
jma92114's Avatar
jma92114
Trailering
Thanks for the clarity Paul. I Appreciate You...
Old Oct 10, 2022 | 09:46 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Paint codes: MW MC
Primary color is bright regatta blue metallic
secondary color is light smoke metallic.
OCJoeR
May 8, 2021 10:28 AM
Marblewilliam
2004 - 2008 F150
Nov 23, 2019 01:12 PM
Chris.Case
Jul 3, 2014 06:58 AM
73'360f100
Jul 23, 2009 08:07 PM
Mil1ion
Jun 27, 2003 04:35 AM
