1999 e250 timing chain replacement?
Old Oct 8, 2022 | 06:23 PM
wizzy214's Avatar
wizzy214
1999 E250 ext cargo van 375k miles what all has to get taken apart for the chain to get replaced, dealer said 12 hrs it can’t be that hard.
Old Oct 8, 2022 | 09:03 PM
econo93's Avatar
econo93
Which engine? If it's the 5.4 then it has 2 chains and lots of parts to remove/replace.
The V6 would be simpler.
Old Oct 9, 2022 | 12:08 AM
ojai150's Avatar
ojai150
you don’t give enough information, what size engine is it ? If it’s a 5.4 , that’s cheap
Old Oct 9, 2022 | 04:03 AM
JWA's Avatar
JWA
Pretty much standard from this OP---seems to believe we're all mind readers here!
Here's an easy to understand on why ANY mechanic would charge a minimum of 12 hours labor replacing a Ford Modular Motor timing chain set PROPERLY:
Parts NOT included!
Old Oct 9, 2022 | 06:18 AM
manicmechanic007's Avatar
manicmechanic007
It's real close to 2500.00 for the job, parts and labor
I would call that a big job
Use only Ford parts if you know what's best for you (a kit on ebay with everything is about 450.00)
fordtechmakeuloco has videos you can watch on YouTube, if you want to do it yourself
craigibc
1997 - 2003 F150
Jun 6, 2023 03:35 PM
b4hntn
1978 - 1996 Big Bronco
May 21, 2005 03:50 PM
Dannym
Dec 15, 2004 11:31 AM
TCJRBS
Aerostar
Aug 28, 2003 03:58 PM
reever
Aerostar
May 30, 2003 08:44 AM
