1995 F150
Old Oct 7, 2022 | 01:42 PM
mxer201's Avatar
mxer201
1995 F150
With 302 and automatic. I think the code being flashed is 33 but can someone confirm? Thanks!
Old Oct 12, 2022 | 06:27 AM
rla2005's Avatar
rla2005
First set of flashes are the Key On Engine Off (KOEO) test results: Code 111 System Pass (twice). The single flash is the separator between the KOEO test results and the Continuous Memory display. The next set of flashes are Continuous Memory Code 111 System Pass (twice).
What issue(s) are you trying to resolve?
Now is a good time to invest in a code reader such as the Innova 3145 to eliminate the errors decoding the flashes.
Old Oct 12, 2022 | 10:48 AM
mxer201's Avatar
mxer201
Check engine light turns on once the engine reaches normal operating temp. No performance issues, starts and rungs fine. But want to correct whatever is causing the light to turn on.
Old Oct 13, 2022 | 04:37 PM
diggerrigger's Avatar
diggerrigger
@rla2005 Here is a link with pertinent information. Scroll down just past the code library and look for MIL LIGHT ACTIVATION.
Your 1995 truck trouble shooting would really benefit from a scanner.
Also, bookmark the sight for future reference.
Old Oct 13, 2022 | 05:18 PM
rla2005's Avatar
rla2005
I watched your video a few times so I am confident it was flashing out Code 111 System Pass for KOEO and Continuous Memory.
I will view it again.
Still a good idea to invest in a code reader.
Workingstiff
Sep 28, 2017 02:21 PM
mcisme
Apr 9, 2004 08:11 AM
