Regearing Questions
Old Oct 7, 2022 | 10:19 AM
rylee95's Avatar
rylee95
Regearing Questions
got a 95 f150 with the 351w and e4od. stock gear ratio is 3.08 and i just put a 4 inch lift and 35s on. i know i should regear but what should i switch to? just a daily driver doesn''t tow
Old Oct 7, 2022 | 11:14 AM
GoinBoarding's Avatar
GoinBoarding
4.10 or 4.56, I'd lean to the deeper gears. What's your local speed limits? My truck is on 33" tires and has 4.10 gears, works decent but I don't think I'd regret to 4.56.
Old Oct 7, 2022 | 11:22 AM
Prototypemech's Avatar
Prototypemech
4.56, or 4.88 would be my vote. 4.88 would be better if you had plans to offroad much. 70mph should yield about 2500rpm in overdrive with 4.88.
Old Oct 7, 2022 | 12:05 PM
Conanski's Avatar
Conanski
4.10 to 4.30 would be my suggestion for good all around performance and fuel milage, don't go to 4.88 unless you want maximum performance and don't care about how quickly it will drain the tank.
Old Oct 7, 2022 | 12:22 PM
GoinBoarding
The beauty of 4.10 is you can grab a D50 third member already geared at that ratio out of a junkyard f250, and only have to set up rear gears. For deeper ratios you'll have to set up two gear sets.
Ben24
Mar 7, 2014 06:47 PM
93f250tn
Jan 6, 2011 02:47 PM
FX4 5.4
Feb 3, 2009 01:24 PM
-=Pit=-
Sep 6, 2008 12:17 AM
spidk43
Mar 22, 2006 05:13 PM
