EPAS STEERING BOX
Old Oct 18, 2022 | 06:55 AM
1954F100ranger's Avatar
1954F100ranger
@33ratrodAs far as horsepower is concerned, I understand. I wanted to add power steering and AC to my inline 6 '67 Mustang and there was not enough power to do both. I had looked at the Borgeson power box/kit option and it is a good kit. I recently installed one on a 1970 Mustang with a 351 Cleveland and it wasn't supposed to fit. After install I measured 5/16" to 3/8" space between the box and stock exhaust manifold.
This morning after I get to my shop, I will measure how short the Prius system can be cut down to. I just cut 3 inches off of it yesterday and it looks like it can be cut 2 more. As far as R&Ps thar have electric assist motors on the racks below the engine, I have only seen pictures of what would go on a very late model Mustang or F150. I think a system off of some compact car would be a possibility. Maybe owners here of small 4ish year old automobile would chime in if their car has an Electric Powered Rack and Pinion Steering. Me not being hands on familiar with Flatheads or Jag front ends, I just don't know how much room there is to work with up under there. If possible, take a picture with a measuring tape from the rack connection up to the firewall where the steering shaft pops out of the firewall. The column would have to be shortened a bit if it turns out that the Prius piece would fit.
ADDED: here is a link to a 2019 Corvette R&P. 2019 Corvette
ADDED: the length of this universal EPAS kit look quite short and this is an all-everything kit. Universal EPAS
Old Oct 18, 2022 | 03:13 PM
1954F100ranger
@33ratrod The Prius motor assembly is 9 inches when the input shaft is cut down as much as possible.
Old Oct 18, 2022 | 08:11 PM
33ratrod's Avatar
33ratrod
1954F100ranger, 9 ins is about the same as the Saturn Vue is. The headers on the flathead don't leave much room between them and the frame rail.
Old Oct 18, 2022 | 08:26 PM
1954F100ranger
It looks like there might be a possible way to mount the EPAS unit on the frame rail and then from the column use a u-joint and short saft making a left towards the EPAS then below coming out of bottom of the EPAS a u-joint and short shaft down the r&p. Firmly mount the unit to the frame rail, maybe kind of inside the frame rail. That looks like the only way around the headers to me.
Old Mar 20, 2026 | 06:15 AM
Christopher2's Avatar
Christopher2
Veteran: Navy
Did anyone here complete one of these, on a 1949 Ford? Would like to see one installed.
Old Mar 20, 2026 | 09:04 AM
Old F1's Avatar
Old F1
It is worth a ask, ... but this is a 4 year old thread.
Old Mar 20, 2026 | 09:09 AM
Christopher2
Veteran: Navy
I agree, if you don’t ask you’ll never know. Kind of like if you don’t ask the answer will always be no.
Old Mar 20, 2026 | 02:33 PM
Old F1's Avatar
Old F1
Unless you are married … then the answer will always be no.
F250racer
Montana Chapter
Apr 30, 2014 08:17 AM
ZOOT
Apr 12, 2013 03:04 PM
51merc
Jun 11, 2010 09:02 AM
Larry Dolan
May 23, 2009 12:55 AM
