Yet Another Shock Thread
Old Oct 3, 2022 | 03:41 PM
rednex's Avatar
rednex
I've been reading and researching and can't make up my mind. My stock shocks are already toast and need replacing but can't seem to figure out what to replace them with.
I know most people are fans of Bilstien 5100's. I've put them on my last two trucks and while they do last longer, I've never felt any amount of difference between them and stock. So I'm thinking of trying something different this time, but just don't have a lot of experience in this area so looking for opinions.
Use Cases
  • Live on ~10 miles of dirt gravel roads here in Colorado. Due to lack of moisture, the roads washboard really bad. I know this is a truck, don't expect it to ride any different, but would like to find something that takes a bit of the spine compression out of the travel on these roads and help me from getting sideways.
  • Tow two trailers: RV Grand Design 310GK-R ~14K lbs loaded and a Big Tex 20GN with Tractor ~12Klbs
Not expecting a cadillac ride, but would like to stop rattling my teeth coming home and have something that doesn't affect my towing in any way. Current thinking is Fox2.0 Smooth body, but wonder if the reservoir version might help with the washboards or is that just money wasted since i'm not doing any heavy offroad. Looks at King Shocks, but can't imagine that they would be a good fit for the money. Open to alternatives, shocks you've had good experience with, etc.
Thanks in advance.
Old Oct 3, 2022 | 03:50 PM
jlalanas's Avatar
jlalanas
So have all Carli suspension on my current ride, so may not be entirely relevant. But I had the Fox/Carli smooth bodies initially then upgraded to the res version, they are better (not sure if they're worth the cost of upgrade but they are better). Hope that gives you some perspective on the standard fox vs res version.
As for the Kings....they are the best but they are very stiff. If you aren't really running your truck fast offroad, they may be overkill. I had those on my 2012 and liked them, but I was running 37s on 18in wheels with low tire pressure....that made a big difference in the ride.
Old Oct 3, 2022 | 04:11 PM
chadstickpoindexter's Avatar
chadstickpoindexter
What about the Bilstein 4600's? Supposedly they ride a little softer. Also, the Rancho 9000's are adjustable... not sure if they can be adjusted to be a bit softer? I don't know much about either one of these (I have the 5100's on my truck and I could tell a little difference, but yes, it still rides like a truck), but maybe they would be another less expensive option to consider?
Old Oct 3, 2022 | 04:56 PM
2004Limited's Avatar
2004Limited
Anybody ever try the KYB Gas-a-just on a superduty?
Old Oct 3, 2022 | 07:14 PM
OBS460's Avatar
OBS460
I've had 5100s on my last 2 trucks and I'm going to ditch my factory shocks soon. My last truck only really towed so the 5100s were noticeably different than the Ford shocks it had until 90k miles. My 22 has 16k miles on it towing and the stock shocks are basically shot. The rear axle hops over little bumps and my front tires are cupping. Ford uses garbage shocks. They were great for the first 2k miles or so then once everything settled they started riding like crap.
I'm going to go with 5100s again. I know they are better for towing from personal experience. The Fox shocks will need rebuilt before the Bilsteins need replaced.
Old Oct 3, 2022 | 07:26 PM
honda250xtitan's Avatar
honda250xtitan
washboards you need less air pressure and softer springs. shocks can help but not much as theyre helping control the movement of the axle. i know, thats not ideal to air down but it is what it is.
i like my fox 2.0s. firm and controlled/planted is how i describe them. we do plenty of trips to lemon reservior near durango, cabin is on a mile or two of washboards and the only real fix is to lock the rear diff so you can go faster without losing traction lol.
Old Oct 3, 2022 | 07:35 PM
traveldawg's Avatar
traveldawg
First, I'll agree with what honda250xtitan said - with washboard roads I don't think shocks will help much.
I had adjustable Ranchos on my 2018 and they were nice. I could adjust the ride from stiff to too much softness; at the softest setting it was like an old Desoto that would float over bumps and dips with no feeling of good grip on the road. But for towing (a GD 310GK-r like yours) the stiff setting was best. If not towing I tuned them to the half way point and was OK with the ride.
When I replace my current shocks I'm going with the 5100's.
Pretty much the deal is - it's a truck and it rides like one; I never did like the way it handled on dirt roads but I think if I lowered the air pressure in those cases I would have had a better ride - but that a hassle - air up and down all the time.
Old Oct 3, 2022 | 08:26 PM
morehouse7's Avatar
morehouse7
I watched a quantitative review a guy did on the Fox vs stock on YouTube and went with them because of it. Big difference for me after changing them, there's a 1 mile strip of city road I drive to drop my daughters off at ballet 3-4 times a week and it's absolutely wrecked. A note on rebuilding them, unless you send a bunch at once it's same or cheaper to buy them new.
Old Oct 3, 2022 | 09:18 PM
Schroedinger's Avatar
Schroedinger
4wd Low
Does anyone know if the Rancho 9000 adjustment changes both compression and rebound damping, or only one?
Old Oct 4, 2022 | 07:08 AM
Joe T's Avatar
Joe T
I have those and I think it changes both.
As for the OP get some with remote reservoirs and adjust tpms pressure as mentioned
Old Oct 4, 2022 | 07:25 AM
RidgwaySD's Avatar
RidgwaySD
Anyone who claims you can not help the ride with shocks has never been in a Raptor. The Fox 2.5 resi's on those trucks make it ride like a dream on washboard, better if you have them custom valved.
With 10 miles a day, which I often do as well on CO mtn roads Fox 2.0 res would be my choice, 2,5's if the budget allows and a set of springs from Deaver though a good ride and hauling a 3000 lb pin weight are generally mutually exclusive.
My F350 gas has 5100's and it is the perfect compromise of performance cost and durability for me. I can feel a substantial difference in shock performance with the 5100s. I also run around 42 psi cold in the rear tires and have 35" tall tires on the truck. Still rides like a truck but with better control. Can still get sideways on washboard but much less so.
Old Oct 4, 2022 | 08:46 AM
Bananasfoster's Avatar
Bananasfoster
FWIW I just replaced the stock shocks that came with my FX4 package with Bilstein 4600s and a steering stabilizer and cannot tell the difference.
I live on a gravel road and tow a fiver too.
Old Oct 4, 2022 | 10:23 AM
GAZZILLA's Avatar
GAZZILLA
Regarding the difference between Bilstein 4600 and 5100’s. I wrote to Bilstein about that and this was their reply…
“Thank you for contacting Bilstein. The only thing that is different is the extended length in front between 4600 & 5100, valving are identical front & rear. Thank you.”
Old Oct 4, 2022 | 10:26 AM
chadstickpoindexter
I had read that there wasn’t really any difference either, but some claim that the 4600’s ride better…
Old Oct 4, 2022 | 10:33 AM
scraprat's Avatar
scraprat
Top Answer: 5
Through the years I've tried the more expensive Ranchos and had Bilstein on my 250/ 350s and could never tell the difference other than in the wallet.
Good old Monroe magnums or Monroe reflex seem to do the job well enough.
