Aftermarket Products
Sponsored by: Worksport
hood insulation
Old Oct 2, 2022 | 11:49 AM
beartracks's Avatar
beartracks
hood insulation
anyone use an under hood insulation kit? Recommendations?
Old Oct 2, 2022 | 04:51 PM
tjc transport's Avatar
tjc transport
i ain't rite
never used it under the hood, but dynamat is about the best there is for in cab sound deadener, and insulation
Old Mar 10, 2023 | 03:50 PM
ezlivin11's Avatar
ezlivin11
i use foam, dynaliner and a new hood liner. This works well, dynamatt is a bit heavy for trunk and hood areas (they slam closed) .because the hood area has heat involved use a fire block foam instead of plane expanding foam. For best results remove hood and lay upside down. when spraying foam inject a small amount then go to a different area moving around and giving some time for the foam to fire off and start expanding, then go back and inject again. I usually do four rounds of this procedure with great results. If you don't give it time the foam will not fire correctly and you end up with a gooey mess Mike/EZ
Old Jun 7, 2023 | 09:09 AM
J.L's Avatar
J.L
3rd Gear
Any pics in dynaliner?
would you post some picture on this dynaliner? I’m new her with a 5.4L 2006 curios to build my girl up.
GeneGregory
Feb 16, 2022 10:15 PM
twr
Apr 14, 2001 07:50 PM
