9" rear end question
Old Sep 30, 2022 | 06:35 PM
stbart's Avatar
stbart
I have a Ford 9" rear end that I got out of a 1970 F100 that I intend to put into my 51 pickup. I only got the rear end, not the U bolts or top plates. I figured they would be easy to get. The U bolts are easy to get, but I am having trouble finding top plates that specifically say will fit 1970 F100. It is the standard 3" axel housing. I found some online that say 67-69. Is there a difference from 69 to 70 housing?
If anyone could share what they have used I would surely appreciate it.
Old Sep 30, 2022 | 08:22 PM
mtflat's Avatar
mtflat
57-72 should all use the same sized top plate. If not it's not too difficult to hog out the holes to adjust to your U-bolts.
Old Oct 1, 2022 | 08:23 AM
ingo's Avatar
ingo
i would say it´s easy to build your own !?
Old Oct 1, 2022 | 09:12 AM
tiger100's Avatar
tiger100
I made top plates, from a piece of 5'' long x5'' wide thick walled rectangular steel tube, split horizontally.
My Ford (not a 9 inch) F100 axle tubes are 2-75 inch.
Geoff.
Old Oct 1, 2022 | 09:14 AM
moejr's Avatar
moejr
Try a spring rebuilder or trailer supply business in your area, also venders like Summit, Speedway Motors & auto part suppliers might have what you need.
Old Oct 1, 2022 | 09:23 AM
ingo's Avatar
ingo
for example like that
busted 55
Aug 5, 2014 01:23 AM
civicmindeddogooder
Jan 29, 2013 06:01 PM
dogman312
May 22, 2002 11:26 AM
jaye
Jan 3, 2001 04:11 PM
Pup
Jul 28, 1999 06:16 PM
