Glowplugs...
Old Sep 26, 2022 | 08:26 AM
cbrown9064's Avatar
cbrown9064
Glowplugs...
Another glowplug thread.
I checked resistance of all 8 via valve cover connectors and they seem in spec.
Here is issue, cold truck, with 40F temp. Turn on ignion, see GPR engage. If I just wait for the 120 seconds (or whatever the computer calls for that day) truck won't start. Power is going out of GP relay the whole time the PCM calls for it.
Cycle the key on for 20 seconds, off, then on 20 secs again truck fires with blue smoke that cleans up within 15 seconds.
Bad glow plugs? They initially light off and then fail when they start to heat up? 120k on truck, possible they are original GP, on a late 1997 build.
Is what I am experiencing "normal" behavior?
Old Sep 26, 2022 | 09:54 AM
Hit Man X's Avatar
Hit Man X
Checked for power at the valve cover connectors?
Why glow for 120 sec? I did for 60 sec once when it was 14F out to see if my tired mill would light, it did. Otherwise when 40F I go until the light is out and zip it over.
What batteries do you have in there? OE cables from 1997? Ever cleaned the ends, ground points and at battery as well as starter?
Old Sep 26, 2022 | 10:46 AM
cbrown9064's Avatar
cbrown9064
Yes, checked for power at VC connectors. Will do that again. Why glow for long period? I dunno, turn key on, get out, get newspaper off driveway behind truck, get back in, no start. Cycle key, start.
Batteries are 11 months old. Biggest and best Interstate had. OE cables, but grounds good and cranks fast.
Will ohm out GPs again (last done last spring) and check voltage at VC connector again also.
Thanks for the hints!
Old Sep 26, 2022 | 01:01 PM
knottyrope's Avatar
knottyrope
what OHM value did you get?
after 120 seconds, they start to cool off and it wont start easy that way
try waiting ten seconds after WTS goes out
Old Sep 26, 2022 | 02:50 PM
FinnishStroker's Avatar
FinnishStroker
GP led mod is good to have.
Or monitor the volt gauge when GPs turn off.
I turn GPs on for 120sec,if it is like -30celsius outside.
alwolfer
Dec 22, 2018 10:02 PM
Bird Hunter
Jan 2, 2010 07:14 PM
Benny D
Aug 26, 2009 08:26 PM
73strokin
17
Oct 8, 2008 10:04 AM
crabio
Nov 15, 2006 07:59 AM
