Sponsored by: Real Truck
Air Horns?
Old Sep 25, 2022 | 06:41 PM
Pappy3831's Avatar
Pappy3831
4wd Low
Air Horns?
Anybody out there install them on your Super Duty? Thinking about it. For a big truck the horn is kind of wimpy so I’d like to beef it up. Any suggestions?
Old Sep 25, 2022 | 09:01 PM
ShelbyHauler's Avatar
ShelbyHauler
I have Vixen train (not really) horns on my Excursion. Got them from Amazon. Horns and air compressor. I added a T fitting off the air tank and an air coupler. With a HF coiled hose, I can reach all 4 tires and fill the airbags when I hook up my enclosed car trailer. It is recommended to have them pointed backward so you do not force water and other debris into them. They are quite loud! If I keep the F350 and sell the Excursion, I'll move them over.
Amazon Amazon
Amazon Amazon
Old Sep 25, 2022 | 09:08 PM
PJWhelan's Avatar
PJWhelan
ShelbyHauler: How much were they? What's the model number of those? What about the wiring aspect, was it hard to do. Any recommendations when running the wires. That's the only thing that intimidates me, it's the wiring.
Old Sep 25, 2022 | 09:30 PM
ShelbyHauler
Click Here for the Amazon page -->
Amazon Amazon
I had to supply the wire, I think I used some 12 gauge from Home Depot. On the Excursion, there is a 12v junction just in front of the brake booster, not sure what there might be on the Superduty, but I am sure it should not be too hard to find something. A relay and fuse tap can be used to make sure its only powered when the truck is running. I added a black horn button to the dash and hid the wires in the space between two panels on the Excursion's dash, but you can also tap into your horn button. Again, this will have to be done differently on the Superduty. I got lucky and was able to mount the air tank using the brackets from the drivers side running board on the Excursion. I haven't looked to see where it might mount on the Superduty. I do know there is a lot of space under the Superduty though, and I'm sure that worst case is you might have to fab up a bracket or two to mount the tank and horns.
Old Sep 26, 2022 | 08:45 AM
Mike1's Avatar
Mike1
Here's a pretty good system if you don't mind the price....watch the video.
https://hornblasters.com/collections...train-horn-kit
Old Sep 26, 2022 | 07:44 PM
Pappy3831's Avatar
Pappy3831
4wd Low
Thanks to all the responses
I really appreciate all your help everybody. From everything I’ve looked at I like the Klein the hornblasters and the vixen. But I don’t have upfitter switches. From the looks of it it’s not too hard to add them but trying to find the right kit. I’ll ask in another thread since that’s a different issue. Thanks again everybody.
Old Sep 26, 2022 | 10:24 PM
ShelbyHauler
I'm not sure I understand the upfitter switch part. Is this a separate item or did you want to use them with the air horn?
Old Sep 28, 2022 | 11:24 AM
Pappy3831's Avatar
Pappy3831
4wd Low
I was planning on wiring the compressor to one of the upfitter switches
Old Sep 28, 2022 | 12:15 PM
ShelbyHauler
I thought of using a switch in my install, but then you forget the switch and try to blow the horns, and no air pressure... I guess if you plan on letting the truck set for a while. When that happens to me, I just pull the in-line fuse in the engine bay.
Smoking Joe
Jul 10, 2017 05:21 AM
Fordman96
Dec 6, 2014 02:08 PM
Marauder92V
6.7L Power Stroke Diesel
Mar 20, 2012 06:25 AM
02GrayPowerStroke
13
Jan 18, 2006 09:23 PM
