Dash Lights
Old Sep 25, 2022 | 02:10 PM
dfitch1's Avatar
dfitch1
Dash Lights
I couldn't help but notice how dim the dash lights are when driving my 79 at night. Yes, the dimming **** is turned up all the way. Has anyone swapped out the lamps for LED,s? If so, where did you purchase and how many, kit or individually bought.
Thanks
Old Sep 25, 2022 | 02:14 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Check out Hipo LED's. Yes it matters how you install then (direction wise). https://www.hipoparts.com/
https://www.hipoparts.com/1961-79-fo...nversion-kits/
Do not forget your dome light also.
Old Sep 25, 2022 | 02:30 PM
dfitch1's Avatar
dfitch1
Thanks for the quick reply, I will check them out. Just out of curiosity, any thoughts on aftermarket rims for my 79 F-250, 8 lug, 2WD? I still have the 16.5 x 9.5. Tires get a little hard too find and pricey as well.
Old Sep 25, 2022 | 03:08 PM
i-w's Avatar
i-w
I just got the hi po led’s
They work great.
I got the elite set.
Old Sep 25, 2022 | 04:31 PM
77&79F250's Avatar
77&79F250
9.5x16.5's are out there. https://www.tirerack.com/tires/TireS...&diameter=16.5
Or here.
Amazon Amazon
Wally world https://www.walmart.com/ip/Power-Kin...Tire/819863055
Other wise it is 16" rim (with the right back spacing to clear the duel piston caliper) or 17" and then you will have a way better choice on tires.
Rims choices are like ice cream flavors now days, 31 and then some...
Old Sep 26, 2022 | 08:03 AM
dfitch1's Avatar
dfitch1
Thanks for the information, were they easy to install?
troverman
Aug 21, 2016 10:32 PM
jleal_21
Feb 14, 2012 10:00 AM
say when
2009 - 2014 F150
18
Dec 19, 2009 05:34 AM
ASoCalCowBoy
Nov 12, 2006 10:13 PM
