Kickdown lever
Old Nov 11, 2003 | 06:23 PM
ivanribic's Avatar
ivanribic
Kickdown lever
Stupid question but I need to know. Is kickdown lever pushed down by the carb when you step on the throttle or does the transmission pull the lever to open the carb up when it's under load?
I installed a raised manifold and 2" spacer. Now I'm trying to figure out how to rig my kickdown lever.
Thanks,
Ivan
Old Nov 11, 2003 | 06:58 PM
Torque1st's Avatar
Torque1st
Posting Legend
You operate the carb throttle which uses the kickdown rod to send a signal to the tranny.
Old Nov 11, 2003 | 07:05 PM
ivanribic's Avatar
ivanribic
Thanks much, that will help me get this worked out.
Old Nov 12, 2003 | 05:22 AM
Supercab's Avatar
Supercab
Cool
I've seen an extension for this in the Jegs catalog.
Old Nov 12, 2003 | 09:11 AM
beartracks's Avatar
beartracks
You may be able to straighten the lever out a little for longer reach. As I recall you need about .015 clearance left between the screw and little lever when you hold the throttle wide open. LOKAR makes a cable assemble.
Old Nov 12, 2003 | 01:03 PM
proeliator's Avatar
proeliator
Yes, when I ended up with a much taller intake, spacer and carb combo my kickdown wouldn't reach. Going to the Lokar cable is fairly cheap, a piece of cake to hook up, and works great.
Old Nov 12, 2003 | 04:05 PM
ivanribic's Avatar
ivanribic
Does the Lokar cable kit replace the whole kickdown arm and route directly to the tranny?
Proeliator: Your truck is insane! State Patrol won't allow anything that crazy in Washington but I'm hoping to fit 39's on my truck in the spring.
Old Nov 12, 2003 | 10:47 PM
Torque1st's Avatar
Torque1st
Posting Legend
Proeliator has one of the best trucks out there! I LIKE it!!!
Old Nov 13, 2003 | 01:24 PM
MISCAB's Avatar
MISCAB
I ran into a problem w/ my kickdown lever years back after swapping engine and tranny.
I wound up cutting one of the levers that was a close fit and welding appropriate size nuts to the cut ends and running a piece of allthread to make the lever adjustable. It worked out fine for my application.
I rather like the Lokar cable idea when I restore my old truck though.
Old Nov 13, 2003 | 03:53 PM
proeliator's Avatar
proeliator
Thanks guys for the compliments It will look better when I paint it. I'm gonna shoot it olive drab with military markings, then throw on some little white sillhouttes of hondas and such on the front fenders for "kills". The cops down here in Oregon are pretty cool with it but yea, Washington fuzz won't even let me cross three miles over the border without jumping on me. Anyways, yes, the Lokar cable comes with a couple of brackets and replaces all of the factory brackets and the cable attaches directly to the rectangular arm coming out of the tranny. It replaces the whole kickdown assembly and connects directly to the carb. Mine works great.
Old Nov 13, 2003 | 05:21 PM
Texan1983's Avatar
Texan1983
i like that paint idea proeliator, definatly should do it.
and get us some pics!
