Just curious
Old Sep 24, 2022 | 08:23 AM
Socalb81's Avatar
Socalb81
4th Gear
Just curious
Whats missing, please?
Old Sep 24, 2022 | 08:51 AM
tabijan's Avatar
tabijan
A description of what this is? First though is a picture of the engine from the cabin, but is that a belt and pulley and sun shining on a tire?
Sixto
07 E350 5.4 183K miles
Old Sep 24, 2022 | 09:09 AM
Socalb81's Avatar
Socalb81
4th Gear
Originally Posted by tabijan
A description of what this is? I’m guessing a picture of the engine from the cabin.
Sixto
yes this is looking down from the cabin of the motorhome, what I was asking I should have circled it there is a hole on the right side with a rubber grommet and a threaded hole next to it that looks like there was something there or it's an attachment for something
Old Sep 24, 2022 | 09:15 AM
tabijan's Avatar
tabijan
Helpful to know engine and year.
My guess is the exposed surface should be attached to the bit just above it. In a sense what’s missing is the bolt that holds them together.
Sixto
Old Sep 24, 2022 | 09:57 AM
Socalb81's Avatar
Socalb81
4th Gear
Sixto
2002 v10 triton everything is tight and motor runs perfect, was just wondering.
Old Sep 24, 2022 | 11:41 AM
tabijan's Avatar
tabijan
Looks different from our ‘07 5.4. The big pipe at the very right of the first picture looks like the transmission dipstick. The hose attached to it is the cabin heater supply line. The worm clamp doesn’t look original but so what if it’s working.
What looks like holes, if that’s what has you curious, might be capped fabrication holes such as to machine the camshaft journals and bosses for other applications.
This is the back end of a cylinder head and transmission bell housing of our 5.4 viewed from the passenger footwell -
Sixto
Old Sep 24, 2022 | 12:52 PM
Socalb81's Avatar
Socalb81
4th Gear
What looks like holes, if that’s what has you curios, might be capped fabrication holes such as to machine the camshaft journals and bosses for other applications.
Sixto
ok thanks so much for your reply
ChrisParker1
Apr 9, 2023 10:30 AM
Cabledude
Aug 30, 2016 05:09 PM
JLortie
Mar 5, 2016 05:54 PM
54TexasF100
22
Aug 24, 2015 06:52 PM
jaye
Dec 19, 2009 09:01 PM
