Stalling Issues
Old Sep 23, 2022 | 05:21 PM
aj1968's Avatar
aj1968
1st Gear
Stalling Issues
Hello all. I have a 1996 F-350 7.3l auto. I am having troubles with the truck idling fine for a while then all of a sudden the check engine light comes on and it seems to have a little more power. However when I let off the throttle it stalls out. Usually fires right back up[. I have so far replaced the valve cover gaskets, fuel pump, the pedal throttle position sensor, crank position sensor, and IPR valve, IPC valve. I also have tried to pull codes but the reader doesn't show any. I am very stumped and really need the truck to make money. Any help would be highly appreciated. Thanks in advance. God bless y'all. Stay safe and healthy.
Old Sep 23, 2022 | 07:14 PM
farmert's Avatar
farmert
If you get a check engine light there should be a code stored. Most generic code readers won't communicate with these trucks. A lot of folks use Forescan and a dongle to read codes on these old trucks. That said, check to see if the tin nut that holds the electromagnet on IPR is tight. They have been known the fall off, causing stalling.
Old Sep 23, 2022 | 08:08 PM
z31freakify's Avatar
z31freakify
Check your wiring going to the ICP, IPR, and the engineer harness for any bare wires
Old Sep 24, 2022 | 06:55 PM
97-psd's Avatar
97-psd
Do you have a way to read live data? If not, as mentioned, get Torque pro or Forscan so you can see what is going on
Walleye Jack
Dec 9, 2014 07:55 PM
jgilrfr
13
Oct 16, 2010 02:32 AM
herrfixit
Dec 30, 2006 09:36 AM
mrboo
17
Oct 8, 2004 10:40 AM
stevieray
Dec 11, 2001 08:21 PM
