Engine/transmission swap
Old Sep 21, 2022 | 04:01 PM
HIAWG12's Avatar
HIAWG12
2nd Gear
I need a lot of help here as im not a mechanic and also have never owned a ford. Ok lets get into this. I have purchased a 92 f150 with a 5.0. That motor has been taken out and the f150 body now has a 97 f250 5.8 motor in it. The f150 transmission is blown and i need to transfer over the f250 transmission. Will this line up or will i run into issues with the drive shaft or electronical issues? Another option i thought of was to just get a refurbished f150 transmission but i didnt know if that would work because it will be hooked up to the 97 250 motor technically. Thanks in advance.
Old Sep 21, 2022 | 06:47 PM
Scndsin's Avatar
Scndsin
The 97 will have an E4OD or a C6.
The 92 will have a AODE or E4OD & can be determined with your data sticker on the door frame if you can post a pic or the trans code.
If you have the sticker from the 97, you can post it's code too.
Can't tell you the # of pan bolts to decipher with off the top of my head.
Old Sep 22, 2022 | 11:47 PM
solanum's Avatar
solanum
Post the door sticker codes. Highly unlikely it will be a direct swap with that large of a year gap, Ford very rarely lets a model year go by without some kind of tweak to the wiring for large components. You never said if this was an A/T or M/T application- the manual-shift boxes most definitely are not a direct swap between those 2 applications, although all the parts you need are fairly easy to come by and there are relatively few electrical items to worry about. The auto-shift boxes will almost certainly not work with the 1992 wiring harness and PCM, even if by chance the driveshafts match up.
If it was my project, and the F-250 trans is known to be good, I'd sell it and then buy the correct trans from a junkyard or rebuilder.
Old Sep 23, 2022 | 10:33 AM
My4Fordtrucks's Avatar
My4Fordtrucks
None of the wiring from the ‘97 would be used. The 302 harness plugs right into the 351W.
You can most definitely install a ZF5 in place of the M5OD. It bolts right in and you can reuse the same driveshaft(s) without change to their length.
The only thing to watch out for would be for an automatic transmission. There was a diode or resistor moved from inside the transmission to the PCM in ‘94 or ‘95. Other than that it is also a direct swap. An E4OD is an E4OD. There wasn’t one specifically made for a 150 and a different one made for a 250/350.
Old Sep 23, 2022 | 01:59 PM
frank5079's Avatar
frank5079
I have the M5OD gearbox behind my 300 I6 to 351 V8 swap and haven't had any problems since I did the swap almost three years ago...
HIAWG12
Sep 21, 2022 06:44 PM
ryan cruse
Mar 21, 2019 09:05 PM
daddyslilmechanic
Sep 11, 2011 04:56 PM
OLD97F250HD
Sep 18, 2010 08:07 PM
pmc
1997 - 2003 F150
Apr 29, 2007 07:01 AM
