Def Delete ?
Old Sep 20, 2022 | 04:13 PM
LARRY MELANCON's Avatar
LARRY MELANCON
1st Gear
Def Delete ?
Good day gentlemen
I am the proud owner of a new 2019 F SD 350. 38,000 miles..My first.
Little history. DEF/EX/EMISS DELETE.
Me being a newbie, i topped off the DEF. Now it is continuously trickling out of the open line from the DEF tank. And covering the underbody..
Will it stop at some point. Pressure equalizing...
Im Assuming there is no need to add def or have it in the tank.
Thanks all
Old Sep 20, 2022 | 04:41 PM
Sport45's Avatar
Sport45
No, you don't have to put DEF in an emissions deleterd truck. It will stop dripping once all of it has drained. The white crystals should easily rinse off with plain water. I'd rinse often as it can be corrosive.
Old Sep 20, 2022 | 05:19 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Why would you put DEF in a deleted truck???
And, that DEF spilling out of there will wreak havoc on any unprotected metal, corrode it very quickly if you don't wash it off immediately.
Then drain the DEF tank so it doesn't spill out any more.
Old Sep 20, 2022 | 06:07 PM
zeroo's Avatar
zeroo
I like the truck, the delete just makes it better. Pull the def tank and spray the contents on your lawn.
Capt'n Jack
All Things Towing
13
Jul 10, 2021 02:03 PM
cowboyup1494
All Things Towing
Aug 16, 2018 10:11 AM
dustydogg31
Jul 9, 2016 07:39 PM
RV_Tech
All Things Towing
38
Jun 16, 2015 04:39 PM
1994diesel
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Apr 19, 2008 05:12 PM
